overheating #715982 04/15/06 11:58 PM
trey58d Offline OP
my 87 Runner w/ a 22RE is overheating, and boiling the coolant on shutdown. the fan is running, upper and lower hoses seem to be clear, but the upper hose isn't hot, which the Hanes manual says is indicative of a thermostat being stuck closed.
so I plan on replacing the thermostat, with a new gasket, and using RVT sealant. also, there are a bunch of vaccuum and other lines running across the top of the thermostat housing. is it going to create any problems to diconnect any of those to access the thermostat?
anything else I should be considering with the thermostat replacement, before trying to look at the water pump or radiator?
Re: overheating [Re: trey58d] #715983 04/16/06 12:04 AM
4Crawler Offline
Carefully label each vacuum line before removing (both ends) and document where they connect.
- http://www.4crawler.com/4x4/CheapTricks/index.shtml#TstatReplacement
Re: overheating [Re: trey58d] #715984 04/16/06 12:05 AM
get a paint marker an mark all your hoses BEFORE you disconnect them. Or take a pic for reference. My guess is your thermostat too BTW, or totally clogged journals, which is much less likely.
Re: overheating [Re: trey58d] #715985 04/16/06 01:44 AM
ZUK Offline
<img src="/forums/images/graemlins/scared.gif" alt="" /> OOPS <img src="/forums/images/graemlins/scared.gif" alt="" /> is right.....overheating this week and blown HG next week. Sorry to put the news to you that way but people have told me that I'm psychotic and can foresee the future <img src="/forums/images/graemlins/cheers.gif" alt="" />
I put my money on the radiator especially if it has high miles. Been there. Done it. ZUK
edit----trey....let me guess....it tends to overheat faster on the highway....going slow around town it's ok.
additional edit---haha! Yours is an 87 22RE.....so was mine with 211K on the radiator. The radiator was my issue but I let it overheat maybe 6 times before I figured it out so the HG went the following week. Lots of white smoke pouring out the exhaust.
mostly stock
Re: overheating [Re: trey58d] #715986 04/16/06 01:55 AM
ZUK Offline
$110.51 .......I believe I got mine from here....took only 3 days to get..... http://www.radiatorbarn.com/s7.asp?...ALL+MODELS&engine_size=L4%2C2.4L
mostly stock
Re: overheating #715987 04/16/06 01:56 AM
trey58d Offline OP
so I just broke the bolt on the thermostat housing closest to the valve cover. what do I do now? and this is my daily...
and I'm sitting at 236k miles. Zuk, it's slightly cooler at speed, climbs faster sitting. I wouldn't be suprised at the radiator, but wanted to go the "easiest", cheapest route first. and it's stayed w/in the marked limits on the temp guage, to try to avoid the HG swap.
Re: overheating [Re: trey58d] #715988 04/16/06 02:11 AM
4Crawler Offline
Overheating while stopped could be the fan clutch, test it to see:
- http://www.barneymc.com/toy_root/techneek/fan_clch.htm
If the broken bolt sticks out enough, try heating it up and see if you can grab it with some vice gribs. Otherwise drill and screw extractor.
Re: overheating [Re: trey58d] #715989 04/16/06 04:43 PM
ZUK Offline
Get the broken bolt out.....got any clear close-up pics of the break? Mcgyver might goop it up with Ultra-Blue RTV and tighten down the one good bolt and let it dry 24 hours. I once did a similar thing for a customer at Checkers in SLC,UT.....3 months later she came in to get something and told me it was still holding great. smile
Your symptom of a cool upper radiator hose and running slightly cooler at highway speeds points to a water flow issue of some sort. How's the tightness on the water-pump belt? Keep us updated.
mostly stock
Re: overheating [Re: ZUK] #715990 04/18/06 05:09 AM
trey58d Offline OP
didn't do anything with it yesterday, because I couldn't get an extractor. today me and a buddy broke the extractor, ran through a couple of drill bits getting that delt with, tapped a new fitting for a m10x1.25 bolt, got it sealed up, and am letting that cure tonight to see if that was what was needed. looks like the old thermostat wasn't opening fully when we played with it, once we got it out.
see how it goes tomorrow.
Re: overheating [Re: trey58d] #715991 04/19/06 02:39 AM
trey58d Offline OP
well, we seem to have fixed it. it's operating higher than it used to before the overheating, but staying just about halfway up the normal operating range of the gage. haven't driven it hard yet, just got it stablized with some easy driving near the house in case it wasn't fixed. so I think it's good.
when I was describing it before, as it was over heating, it would heat faster in slow or stop and go traffic, but would heat slower (but continuously) when up to some speed.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6415 MB (Peak: 0.7675 MB) Data Comp: Off Server Time: 2026-06-23 21:19:31 UTC
