Re: Top end noise, looking for TECH suggestions
[Re: fasteddy]
#716269
04/17/06 08:35 PM
I think all the truck V6's have rollers. I would pull a valve cover to look for the source of the noise.
Kevin
[Re: DaphneD]
#716270
04/17/06 11:44 PM
What to look at? Take the covers off and stare at it until the answer squirts me in the eye?
Tech help please. Sarchasm engine in the final stages of development!? <img src="/forums/images/graemlins/lol.gif" alt="" /> Hate to hear your motor is junk <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />
[Re: Kevin C]
#716271
04/18/06 01:13 AM
It must be on the cam side then. I don't remember it very well. I'll have to look at the one on my bench at work tomorrow.
Clay
KG6VNX
[Re: 52degrees]
#716272
04/18/06 03:24 AM
Mitsu/Raider 3.0Ls had rollers.... the early Chrysler 3.0L variants did not.
Frank
[Re: DaphneD]
#716273
04/18/06 11:59 PM
Doug,
I had a similiar sound coming from my 3.0 after changing the timing belt. I thought it was the lifters becuase the sound seemed to be coming from the top end. Well, after 3000 miles I decided to take a look. Sure enough the tensioner was loose. Re-adjusted and the sound went away. A look see at the belt is a bit easier than pulling the v-covers in my book (no gaskets).e
1989 Montero LS (sold) 1994 Cherokee Country bone stock
[Re: v6lsmonty]
#716274
04/19/06 12:50 AM
Doug,
I had a similiar sound coming from my 3.0 after changing the timing belt. I thought it was the lifters becuase the sound seemed to be coming from the top end. Well, after 3000 miles I decided to take a look. Sure enough the tensioner was loose. Re-adjusted and the sound went away. A look see at the belt is a bit easier than pulling the v-covers in my book (no gaskets).e Honestly, that's the same thought I had just yesterday. Going to check things out this weekend hopefully.
[Re: DaphneD]
#716275
04/20/06 02:35 AM
I hope that is it. Good luck. If that does not work pour one of your mitsu beers in the oil fill tube it might like that. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: DaphneD]
#716276
04/20/06 05:04 AM
Doug, I have read that some of the newer oils have less high pressure additives to improve converter life. It might be that a older engine oil with more EP additives would work better. Also a 10-40 may get you a bit more film strength. I ahve been running the 5w-40 wt Mobil 1 truck oil with good results. www.bobistheoilguy.com has good info. Kevin
