Need info on this tire carrier Jerry Can mount please
#716298
04/17/06 03:46 AM
I believe this must belong to someone here on the board. I would like to know where this Jerry Can mount came from, as a friend who lives in SLC, Utah wants such a thing for his Jeep. He is a avid varmint hunter and gets WAY off the main roads about every other weekend. TIA ![[Linked Image]](http://216.77.188.54/coDataImages/p/Groups/15/15729/folders/144233/1021214monteroladder.jpg)
Re: Need info on this tire carrier please
[Re: jeepdriver]
#716299
04/17/06 03:52 AM
The tire carrier is stock with a spare tire mounted gas can bracket.
[Re: DaphneD]
#716300
04/17/06 04:09 AM
Thanks Doug, I meant the Jerry Can mount, I corrected the post.
Too many 4x4's, not enough time or money
[Re: jeepdriver]
#716301
04/17/06 04:15 AM
Gas can carrier is made by Con-Ferr (conferr.com) but you have to fab a piece that extends from your spare tire mount and holds the can carrier. An aftermarket part may be available but may only be available for a 5 lug pattern.
[Re: off-roader]
#716302
04/17/06 04:38 AM
You can buy the complete mounting hardware kit from Conn-Fer dealers. OffRoadRecovery Warehouse ![[Linked Image]](http://i46.imagethrust.com/t/410300/img1694.jpg) Frank
Re: Need info on this tire carrier Jerry Can mount please
[Re: jeepdriver]
#716303
04/17/06 04:42 AM
![[Linked Image]](http://www.lesjackson.com/wheels/back.jpg) I have one, I have one ! <img src="/forums/images/graemlins/smile.gif" alt="" /> Got mine at 4wheelparts.com it's by ConFer. I came in real handy in Death Valley. <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: LRJ4x4]
#716304
04/19/06 04:45 PM
I've got the Con-Ferr tank holder just like that. The difference is how I mounted tothe spare tire rack. In the center of the spare wheel while it's mounted on your rig ,you will notice a smaller diameter hole that is on/in the tire mount itself. If I remember correctly it's around 4". This is where I used a steel galvanised 4" pipe reducer behind the hole to secure a short length on the outside called a coupler ( 4" Galv. steel ). This always stays on the truck. Now for the con-ferr part , I constructed a 1/4" plate roughly 4" x 6" with 4 holes to bolt to the existing holes on the con - ferr. To this flat plate I welded a 2" long section of threaded steel that fits the coupler that is always mounted to the truck. When I want the extra fuel can on I just spin the can/mount on . It takes about 15 full spins so there are plenty of threads engaging. As a bonus when I fill other containers I just tilt/twist the whole can over to one side so I don't have to lift and most likely spill. I siphon mostly. Sorry about long explanation but I have no camera. When I did final tightening of reducer/coupler on truck I indexed it in right spot so that when spinning the fuel can on it tightens/bottoms out at a straight up position. Also when I installed th coupler/reducer I used a HUGE pipe wrench. No lock-tite or anything and its been there for years (probably rusted on). Also the protruding coupler aids in lifting your spare tire on. The wheel goes up onthe coupler and holds it there and then you spin it to match the wholes to the three lugs. Good luck.
[Re: jeepdriver]
#716305
04/19/06 05:32 PM
Anyone have info on the ladder? Or is it homemade? Thanks!
1988 montero 31X10.50X15 Pro Comp A/Ts on 15X8 Rock Crawler 97s Weber conversion with carter fuel pump. Roof rack in progress.
[Re: oewii]
#716306
04/19/06 05:37 PM
Not sure if it's the same, but it reminds me of McV's Disco ladder that he put on one of his rigs...IIRC
