Scan: Exploded view of 12-bolt? #716460 04/17/06 05:10 PM
F
Fujisawa_Rob Offline OP
Can someone with a factory service manual scan an image of the 12 bolt axle, specifically the detail of the hub and bearing assembly? The Haynes manual has one, but I think it's a 10 bolt. I need to replace the oil and/or grease seals, and would like to be able to tell in advance what tools I need (slide hammer, bearing puller, etc). Thanks.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Scan: Exploded view of 12-bolt? [Re: Fujisawa_Rob] #716461 04/17/06 05:54 PM
TommyC Offline
I know this site isn't exactly what you were looking for, but I think it's useful, and is mostly applicable to my 86 as well. Thanks be to the kiwi...
PDF LINK
Re: Scan: Exploded view of 12-bolt? [Re: TommyC] #716462 04/17/06 08:51 PM
F
PDF LINK
Nice write up, but the rear will be different.
They get all the cool stuff overseas...2.8 Turbodiesels...softtop Troopers..wah!
Re: Scan: Exploded view of 12-bolt? [Re: Fujisawa_Rob] #716463 04/17/06 09:58 PM
bob large Offline
Steve C
Re: Scan: Exploded view of 12-bolt? [Re: Fujisawa_Rob] #716464 04/17/06 10:32 PM
Troopersphere Offline
Will the explodes from a parts manual help ?
See THIS THREAD
One thing I wanted to clarify for myself... Jerry or Litnin might know for sure... Do I understand correctly that the shims that are shown (#39) are ONLY used on the 10 bolt, and NOT the 12 bolt ?
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Scan: Exploded view of 12-bolt? [Re: Troopersphere] #716465 04/18/06 01:27 AM
JLEMOND Offline
THAT IS CORRECT , THOSE SHIMS ARE USED TO SET THE PRELOAD ON THE REAR AXLE BEARINGS ONLY ON THE 10 BOLT , THEY ARE A TAPERED ROLLER BRNG INSTEAD OF A SEALED BALL BEARING LIKE ON THE 12 BOLT,ODDLY ENOUGH THE SHOP MANUAL FOR THE 10 BOLT CALLS FOR THE BEARING TO BE PACKED JUST LIKE A FRONT WHEEL BEARING , ALTHOUGH I DON,T HTINK IT EVER GETS DONE , AS YOU WOULD HAVE TO DISSASSEMBLE THE AXLE ASSY TO GET THE BEARING OUT SO YOU COULD PACK IT AND IN THE PROCESS PROB, DESTROY THE BRNG JERRY
Re: Scan: Exploded view of 12-bolt? [Re: Troopersphere] #716466 04/18/06 02:39 PM
F
See THIS THREAD
Thanks for..um..searching for me.
Re: Scan: Exploded view of 12-bolt? [Re: JLEMOND] #716467 04/18/06 03:26 PM
F
Jerry,
If I'm leaking grease and/or gear oil down the brake splash shield, am I looking at replacing the outer seal as well as the inner? thx
Re: Scan: Exploded view of 12-bolt? [Re: Fujisawa_Rob] #716468 04/19/06 12:20 AM
JLEMOND Offline
NO JUST THE INNER SEAL PT NO IS 894178 2770 , ONE THING YOU WANT TO CHECK AFTER REPLACING THE INNNER SEAL IS THE DIFF VENT MAKE CERTAIN IT IS OPEN , IF IT IS PLUGGED IT WILL CAUSE A PRESSURE BUILD UP AND FORCE THE FLUID PAST THE SEAL, AND INTO THE WHEEL BEARING & WASHING THE GREASE FROM IT AND CAUSING IT TO FINALLY DIE , ALLSO WHEN YOU GO TO INSTALL THE NEW SEAL BE CERTAIN AND PACK THE INSIDE OF THE SEAL WITH CHASSIS GREASE SO THAT THE GARTER SPRING DOESN,T JUMP OUT WHEN YOU DRIVE IT IN AND DRIVE IT IN AS SQUARE AS YOU POSSIABLY CAN. IF YOU HAVE TROUBLE FINDING THE SEAL LET ME KNOW ,JERRY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6295 MB (Peak: 0.7339 MB) Data Comp: Off Server Time: 2026-06-17 02:56:27 UTC
