Re: Slipage.!!!!!!! [Re: MWR4U] #716639 04/28/06 01:18 PM
Dave Scott Offline
wow, i don't think that's happened before with a sportage. heard of it happening in other trucks though. hope you get it worked out. i will be looking for some diffs this weekend, so, i'll let you know.
Re: Slipage.!!!!!!! [Re: Dave Scott] #716640 04/28/06 06:07 PM
DamKia Offline
Kia Moderator
Thats the way both my front pumpkins ended up, split from the dowels to both edges of the casing, ie., two halves, lots of metal fragments, "gummy" gears (no teeth, like your grandma <img src="/forums/images/graemlins/smile.gif" alt="" />)
Re: Slipage.!!!!!!! [Re: DamKia] #716641 04/28/06 11:53 PM
MWR4U Offline OP
Well I found 2 junk yards that had the complete assembly near me. The first said they had plenty of them to choose from and they were only $350.00 and they pull it for you. The second said they did not know if they had it but for a $1.00 I could search the Yard and if I found one it would be $39.95 + $10.00 core charge but I had to pull it. Well I got up early drove about 100 miles (the other yard is only a couple of miles away from it.)paid, a $1.00 to searched the Yard, and found 2 of them. Checked out after spending about 30 min. removing the assembly and got charged $40.00 and they waived the core charge.. Came home placed the assembly in and works fine.. Not bad for a days work..
If it ain't broke, it will be..
Re: Slipage.!!!!!!! [Re: MWR4U] #716642 04/28/06 11:55 PM
MWR4U Offline OP
Oh by the way keep my core so I now have a good ring, pinion and housing...
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6059 MB (Peak: 0.6779 MB) Data Comp: Off Server Time: 2026-05-29 17:07:42 UTC
