body lifting #716871 04/18/06 05:53 PM
L
lu0902 Offline OP
I have most of the procedure down except for one detail. Question regarding the front brake lines. Will I be disconnecting or unbending the hard lines or soft brake lines. Do I have to extend any brakes lines, soft or hard. Thank you. A pic would really help. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1987 DODGE RAIDER 4X4, 2.6 LITTER, 5 SPEED MANUAL MODS+PARTS:
Re: body lifting [Re: lu0902] #716872 04/18/06 06:14 PM
powerRam50 Offline
just unwind some of the hard line inside of the fender that way as you lift the hard line will slide thru the hole in the inner fender the soft lines are fine.
Re: body lifting [Re: powerRam50] #716873 04/18/06 06:43 PM
LandRaider Offline
Remember to make sure your lines are not rubbing the body after you are done. That would create a rub, and potentially rub through your brake lines.
Re: body lifting [Re: lu0902] #716874 04/18/06 06:51 PM
L
lu0902 Offline OP
So I am unwinding the hard line from inside the engine bay, is that right.
Re: body lifting [Re: lu0902] #716875 04/18/06 08:15 PM
LandRaider Offline
Correct
Re: body lifting [Re: lu0902] #716876 04/18/06 08:19 PM
CapnCrunch Offline
Yes, just unbend some on the engine-bay side and feed it through. Once your lift is completed, bend it to accommodate the new angle where it feeds through the hole in the body.
As mentioned, make sure that once you're done none of the line is rubbing on the body where it passes through. There are one or two folks here who overlooked that detail and wound up suddenly without brakes as a line was worn through.
What size lift are you doing?
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: body lifting [Re: CapnCrunch] #716877 04/19/06 12:02 AM
sparkem Offline
This happened on mine. I did not suddenly lose brakes, but noticed I kept losing fluid. I found the leak and fixed it. Could have been a lot worse.
Re: body lifting [Re: lu0902] #716878 04/19/06 04:22 AM
L
lu0902 Offline OP
Going with a 2" lift. Sorry I know I am a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />, but in order to unwind the hard brake line I have to disconect it from the master cylinder, is that right. Just want to be sure. Thank you.
Re: body lifting [Re: lu0902] #716879 04/19/06 04:53 AM
powerRam50 Offline
no you dont have to disconnect it.
Re: body lifting [Re: powerRam50] #716880 04/20/06 02:33 AM
Tag Offline
The lines can flex frairly easily with your hands. I was afraid I was going to kink mine while I was doing it but it was fine.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.014s) Memory: 0.6301 MB (Peak: 0.7374 MB) Data Comp: Off Server Time: 2026-11-17 11:05:57 UTC
