Page 2 of 3 1 2 3
Re: And so it begins...the search for the perfect Troop [Re: Sturdy] #716943 04/19/06 08:24 PM
Rezkid Offline OP
I'd love to have an 93 RS, but I've only ever seen one
If I could find one I'd get it in a heart beat.
2000Trooper, why 97? I'm kinda leaning more towards a 95.5-97, does the 97 have any advantages over a 95 or 96? I deffinetly want the DOHC so that means a 96,97 or a 95 LS, SOTF doesn't bug me too much but i really don't want TOD. thanks for the advice guys, keep it coming <img src="/forums/images/graemlins/kewl.gif" alt="" />
'80 Isuzu LUV, 3" BL, cranked t-bars, small tires and not alotta power
'92 Rodeo...work in progress
Hmmmm...DIRT!!!
Re: And so it begins...the search for the perfect Troop [Re: Rezkid] #716944 04/19/06 08:59 PM
2000Trooper Offline
I picked a 97 just because itÆs the newest of the Troopers with the standard 12-bolt rear axle.
I think I reached the limit on my 2000 Trooper as far upgrades I can do to it without requiring major work.
Here is a list of things I found out about the 98 and newer Troopers:
  • Modified rear axles, beefier but no choices in gears.
  • As per ARB, 98 and on Troopers with rear LSDs donÆt have a locker available. (You could always look for a non-LSD third from a 98 Trooper, although I have heard that they are hard to come by)
  • No lower gears for TOD transfer cases.
So my next upgrade will be swapping the rear axle with a 97 Trooper axle. Will give me more gear choices and the availability of an ARB locker.
I was planning on replacing the TOD transfer case with a 98 Trooper non-TOD transfer case, but when I was comparing the design of the transfer cases, the hole locations donÆt look like they will line up!
Non-Tod
Tod:
In the case of the 97 Trooper, you will have none of the issues listed above and still have a fairly new Trooper.
Jaime
Re: And so it begins...the search for the perfect Troop [Re: 2000Trooper] #716945 04/19/06 10:17 PM
Rezkid Offline OP
Thanks for the info 2000,I'll keep that in mind when I'm looking. I think I've pretty much narrowed it down to what I'm looking for:
95.5,96,97 Trooper
DOHC 3.2
MUA-5 tranny
LS for the 95.5, and for the later years trim doesn't really matter, I mean who needs leather anyway <img src="/forums/images/graemlins/drunk.gif" alt="" /> (on this are there any other major options I should be looking for? I know the G80 LSD is something I'll be looking for, anything else that would be nice to have?)
Color, hmm doesn't really matter too much, i like most of them
thats about all i can think of, all of the advice has been great guys <img src="/forums/images/graemlins/kewl.gif" alt="" /> thanks a bunch
Hmmmm...DIRT!!!
Re: And so it begins...the search for the perfect Troop [Re: BigSwede] #716946 04/20/06 12:31 AM
RockSolidTrooper Offline
Sorry typo...Ls i meant.
Re: And so it begins...the search for the perfect Troop [Re: Rezkid] #716947 04/20/06 12:48 AM
Socalboke Offline
I have a 96 tooper and have had no problems with the SOTF, the manual hubs still work perfect, you have to be carefull not to damage the shifting unit but it is tucked up pretty high so you'll have other problems if you wipe it out. inside there isn't much difference from 95 on I think what makes your search hard is that 5 spd when you find that you'll have to take what ever trooper it comes in.
Good Luck Reid
Reid
96 Trooper, 94 Amigo, 89 swb RS trooper
Re: And so it begins...the search for the perfect Troop [Re: Socalboke] #716948 04/20/06 12:59 AM
Rezkid Offline OP
Yeah thats the prob, almost all of the Gen 2's are auto, I could stand an auto but a manual is sooo much more fun <img src="/forums/images/graemlins/evil.gif" alt="" />
Thanks for the info on the SOTF, I'm planning on adding some Aisins after i get it so that kinda defeats the purpose of SOTF <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> but it's nice to know that it's all tucked up under pretty high out of harms way.
Hmmmm...DIRT!!!
Re: And so it begins...the search for the perfect Troop [Re: Rezkid] #716949 04/20/06 01:23 AM
W
Wareagle Offline
95.5,96,97 Trooper
DOHC 3.2
MUA-5 tranny
You may be a bit more limited than you think. The MUA5 is not avialble w/ the 3.2DOHC in '95 or 95.5. The 96&97 may have a MUA5 option, but I never found one. The 98+ runs the AR5 tranny, so no tera option is available.
Re: And so it begins...the search for the perfect Troop [Re: Wareagle] #716950 04/20/06 04:26 AM
Rezkid Offline OP
Hmmm, I was under the assumption that all 95.5 LS models had the DOHC 3.2 regardless of what tranny they had. And i know that 96 and 97 manuals exsist, good friend of my parents had a 96 manual(true i don't know if it had the MUA5, but I would assume it did)
Wareagle yours is a 95.5 right? and has the manual tranny yet it's an LS and it doesn't have the DOHC?? Oh boy this is going to be a bit harder than i thought <img src="/forums/images/graemlins/drunk.gif" alt="" />
Hmmmm...DIRT!!!
Re: And so it begins...the search for the perfect Troop [Re: Rezkid] #716951 04/20/06 05:17 AM
96TrooperSE Offline
Why do you want a DOHC? The SOHC and a couple more horses and its a lot easier to change the timing belt.
I've got a 96 SOHC and it is great. The SOTF went out last winter, but its an easy fix.
Not sure when they put the Coil on Plugs on(my 96 has them), but that is something you may want to consider also.
OH, and don't forget about the HUGE sunroof the higher models have! <img src="/forums/images/graemlins/lol.gif" alt="" />
/1996 Trooper SE\
OME 912's w/2.5" spacers, Superwinch hubs, 265/75R16 Yokohama Geolanders (street), 34x10.50x15 Super Swamper LTB's, Indy4x HD Tie Rods, Indy4x Rock Sliders
Re: And so it begins...the search for the perfect Troop [Re: 96TrooperSE] #716952 04/20/06 07:59 AM
Rezkid Offline OP
Hmmmm no major reason for wanting the DOHC other than it has more power, I supose I could get by with a SOHC, diffinetly would be easier to find what I'm looking for
Well I've found one thats about 70mi from me
96 LS
190hp SOHC
5-speed
140,000mi
Red (Red Rock Pearl Metallic)
Don't know what all options it has, I'm going to e-mail the seller and see if I can get some more info on it, and some pics as well
Hmmmm...DIRT!!!
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6401 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-07-11 08:12:28 UTC
