Page 3 of 3 1 2 3
Re: And so it begins...the search for the perfect Troop [Re: Rezkid] #716953 04/20/06 12:37 PM
W
Wareagle Offline
YOu are correct. My trooper is a 95.5 LS w/ SOHC.
Also, 96 is when the coil om plug began.
Re: And so it begins...the search for the perfect Troop [Re: Rezkid] #716954 04/20/06 02:12 PM
BigSwede Offline
The pre-98 SOHC/DOHC 3.2L are almost the same engine. In fact you can swap the heads and "convert" a SOHC to DOHC rather easily if you care to, according to Jerry Lemond.
The SOHC has the lifter tick sometimes, but it is not harmful, just noisy. I guess I wouldn't limit myself to the DOHC just because of that.
Serenity now!
Re: And so it begins...the search for the perfect Troop [Re: BigSwede] #716955 04/20/06 05:33 PM
really???? <img src="/forums/images/graemlins/smile.gif" alt="" /> Has anyone on here attempted this by chance? I searched and couldn't find anything. I'm usually pretty good about finding what I want on it, but i couldn't turn anything up. Any info would be awesome, I might end up doing this cause that darn lifter just annoys the hell out of me <img src="/forums/images/graemlins/angry.gif" alt="" />. I've had too many vehicles that knock and although I know it's just the lifter ticking, it still pisses me off to no end. Thanks and keep wheelin' <img src="/forums/images/graemlins/cheers.gif" alt="" />
Rob
Re: And so it begins...the search for the perfect Troop #716956 04/20/06 09:19 PM
Sturdy Offline
If you are not in a hurry 93 RS's turn up on traderonline every month two. If you need to get into something quick, the 93 RS is not for you. I wasn't even shopping for one when I bought mine. It was a right place (ebay) right time (I had money) right price (cheap) deal.
Good Luck
Michael
Mike
04 Tundra
01 Discovery
93 Trooper RS- Lifted, Locked- SOLD
93 Trooper RS- Teras, Lifted, Locked- ROLLED&SOLD
87 Trooper-Lift-SOLD
90 Trooper-Teras and lifts-SOLD
96 Trooper-Graveyard
Re: And so it begins...the search for the perfect Troop [Re: Sturdy] #716957 04/20/06 09:24 PM
Rezkid Offline OP
I don't really need to get one anytime real soon, Looking to be into a Troop by mid-June. I may be willing to wait for an RS to come my way (although I was searching autotrader last night and found a sweet '88 2 door LS that was very well taken care of, and I also found a '93 LS 5-speed DOHC) I'll keep looking but i may be tempted to go with a older one.
'80 Isuzu LUV, 3" BL, cranked t-bars, small tires and not alotta power
'92 Rodeo...work in progress
Hmmmm...DIRT!!!
Re: And so it begins...the search for the perfect Troop #716958 04/21/06 12:30 AM
JLEMOND Offline
HAVE 3 OF THEM RUNING RIGHT NOW AND THEY RUN MUCH BETTER AT LOW RPM THAN THE REAL DOHC SET UP, WITH THE DUAL INTAKE RUNNERS,, JUST INSTALL A COMPLETE 3.2 DOHC CYL HEAD ASSY AND USE YOUR INTAKE SYSTEM , EX, BOLTS RIGHT UP AND SO DOES THE TOP END , YOU WILL NEED THE T BELT AND THE TENSIONER FOR THE DOHC ENG , NO WIRING CHANGES AT ALL THE TOP END DOESN,T KNOW WHAT IS ON THE BOTOM END , NEITHER THE ECM, IT RUNS FINE AND WILL EASILY PASS ANY EMMISSION TEST , WILL RUN ALLMOST AS GOOD AS THE NEWER 3.5 AND WILL RUN AWAY FROM THE NEWER 3.2 , BY USING THE SOHC MANIFOLD ON THE TOP YOU IN EFFET MOVE THE TORQUE CURVE DOWN CLOSER TO 34=35 00 RPM INSTEAD OF THE 3800 TO 4 K IT IS QUITE NOTICE ABLE 95 HEADS ARE THE LATEST YOU CAN USE THE 98 AND LATER HEADS WON,T FIT YOUR BLOCK JERRY
Re: And so it begins...the search for the perfect Troop [Re: JLEMOND] #716959 04/21/06 01:20 AM
Rezkid Offline OP
Jerry I must say your are a wealth of knowledge, i don't know what we'd do if you weren't here.
I'll keep that in mind about using DOHC heads on a SOHC, that right there may just sway me on what engine i go for. Thanks
Hmmmm...DIRT!!!
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6212 MB (Peak: 0.7320 MB) Data Comp: Off Server Time: 2026-07-13 11:49:23 UTC
