Oh No!! 88 trooper help!
#716992
04/19/06 12:48 AM
oh no what happened.... i stopped and washed truck washed under the hood to get rid of dirty and see where oil leak is from ...drove home and it startesd to sputter , poor power and shake...slowed down to turn corner and it stalled ...started again ....then slowed and it died.....got out and checked antifreeze resevoir is over full.....tried to start again and when it did( some cranking) there was terrible white blue smoke that came out of exhaust......quite a bit also.....had to keep it reved so could so would stay running... HELP!!!!!! what happened??
Re: Oh No!! 88 trooper help!
[Re: tobeornottobe]
#716993
04/19/06 01:36 AM
You didn't wash under the hood with the engine hot, did you?
That's a real good way to crack or warp a cylinder head.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
[Re: litnin]
#716994
04/19/06 02:09 AM
It was already on it's way out...
C/YA! Jeff '88 Trooper 2DR LWB 4ZE1 5SP bone stock DD
[Re: Troopersphere]
#716995
04/19/06 06:39 AM
Time to look into a head gasket change. How long did you run the truck after the white smoke appeared? You may get lucky and simply have to replace the gasket (like me), or you might be buying a new head. There is all the information you'll need on these forums if you search. Good luck and welcome.
- Jim
1989 Isuzu Trooper II - 2.6L 4ze1 Motor - BFGoodrich 235/75/15 AT
[Re: tobeornottobe]
#716996
04/19/06 07:52 AM
Isuzu Moderator
Everything you need to know is, HERE. You are dealing with the same problem you had before. In fact, with that low of compression in that one cylinder, you should not have been driving it at all. Good Luck, Michael
[Re: thepcguy]
#716997
04/19/06 04:38 PM
yes i did wash under hood while warm........crap learn the hard way ok wont do that any more, it only ran for about max 2 min. just about 2 blocks..am towing it to mechanics in next couple of days..can i just hook on and throw in "N" and pull it...someone said this may not be a good idea. oh well i guess now ill see whats inside! thanks
[Re: mlclark]
#716998
04/19/06 04:42 PM
I should not have been driving it? I did not read that any where!!! oh well guess we see whats going on in there...and yes there is lots of good info that i will relay to my mechanic...thank u will let u know how it goes..
[Re: tobeornottobe]
#716999
04/19/06 05:36 PM
I should not have been driving it? I did not read that any where!!! Typically one wouldn't drive a vehicle that was showing signs of impending doom (low compression) Jay <img src="/forums/images/graemlins/mrt.gif" alt="" />
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350 1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50 1983 Chevy Blazer - Stock - $150 No Car Payments - PRICELESS
[Re: ISueYou]
#717000
04/21/06 04:12 AM
ok well guess now i know!! learned something new then....as i am very uneducated in the auto field. lol thanks hope to have it towed in next few days. then will see whats up!
[Re: tobeornottobe]
#717001
04/30/06 03:42 AM
I don't mean to oversimplify but did you check your spark plug wires or see if maybe you cracked a plug?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6285 MB (Peak: 0.7202 MB) Data Comp: Off Server Time: 2026-05-29 18:51:34 UTCValid HTML 5 and Valid CSS
