rear track bar panhard bar #717061 04/19/06 04:27 AM
G
grifter679 Offline OP
i jsut lifted the rear of my 92 Sr with 2.5 inch valley spring coils, now the axle has been shifted to the right about .5-.75 of an inch, what have you guys done for relocating the axle to its proper location, i have been looking at an adjustable panhard bar for a jeep from rubicon express like the one my buddy has on his jeep, all ideas welcomed
Re: rear track bar panhard bar [Re: grifter679] #717062 04/20/06 02:36 AM
G
bump
Re: rear track bar panhard bar [Re: grifter679] #717063 04/20/06 03:25 AM
Grifter. I don't recall my 90 having that issue with either a 2 or 3" longer rear spring. You can also check with CAP510 to see if he had that issue. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: rear track bar panhard bar [Re: off-roader] #717064 04/20/06 05:23 AM
Mitsulvr Offline
I noticed that with mine today after reading this. It has something to do with the fact that the panard bar is sitting at a different angel now. This changes it horizontal length I guess is how to say it. You would need to chage the length of the bar to correct the problem.
I think. Please correct me if I'm wrong, still kind of new with this lifting trucks thing.
Eric Wegerich
89 Montero as chopped as can be. Now with 5.29's
Re: rear track bar panhard bar [Re: Mitsulvr] #717065 04/20/06 05:39 AM
52degrees Offline
I keep looking at mine trying to find something like that but it isn't there.
Maybe you have another problem?
Clay
KG6VNX
Re: rear track bar panhard bar [Re: 52degrees] #717066 04/20/06 06:12 AM
DougH Offline
Mitsubishi Forum Moderator
It always changes the location of the axle when you lift it. Simple geometry lol. <img src="/forums/images/graemlins/pfft.gif" alt="" /> a(squared) + b(squared) = c(squared) . Change the length of a or b and c changes, too bad on our rigs c is the panhard bar and it isn't getting any longer on its own, so to compensate the axles shifts over.
I would get a local fab guy to cut the bracket on the frame off and drop it down a little. <img src="/forums/images/graemlins/kewl.gif" alt="" />
You could also build a new rod using a threaded section so you can make it longer or shorter.
DougH
1995 SR - RIP
1993 RS - RIP
Re: rear track bar panhard bar [Re: DougH] #717067 04/20/06 06:40 AM
Angelo Offline
Doug is right, its simple geometry! If your lateral rod (panhard bar) is a certain length, as soon as you raise it at all, its gonna pull the axle in closer to the side its connected to the frame. You can get a fab shop to custom make a new one, maybe even an adjustable one for future upgrades, but another simple way is to get a fab shop to lower the bracket back to its factory height. I never once asked what others have done to correct this. When I purchased my lift, I also got an adjustable lateral rod that can accomidate up to a 4" lift. I dont know any other company out there, you'd have to ask other Gen II owners what they did.
Good luck,
Angelo
Re: rear track bar panhard bar [Re: Angelo] #717068 04/20/06 07:04 AM
G
im not near my truck since im at school, what is the length of the track bar, im looking at a rubicon express adjustable track bar, and need measurements for reference
Re: rear track bar panhard bar [Re: grifter679] #717069 04/22/06 07:55 PM
DougH Offline
If it stops raining and it dries up I will try to to give it a quick measure.
DougH
1995 SR - RIP
1993 RS - RIP
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6261 MB (Peak: 0.7300 MB) Data Comp: Off Server Time: 2026-06-20 18:44:25 UTC
