lincon locker? #717179 04/19/06 06:13 PM
thinking of doing a linclon locker. Lsd's seem to do what they want most of the time. My rig is set up for the street with big sway bars and it corners like a sports car, so it has almost no flex at all. This is my summer rig and I can swich the diffs out as it only takes about 1 hr or so This sould help alot I wish it was an auto, the 5 speed is a pain in the a$$ a. I think this shoud make it a better trail truck or is it worth it with a 5 speed.
Re: lincon locker? #717180 04/19/06 07:25 PM
LandRaider Offline
Sounds like a bad idea for a street truck.
Re: lincon locker? #717181 04/19/06 07:53 PM
Why does your LSD not work properly? Are your clutch plates worn out?
So are you trying to get it to run better on the street or off road?
Re: lincon locker? [Re: LandRaider] #717182 04/19/06 08:14 PM
It would be diven as a trail rig at this point and not a dd. to trail and back a lot of hwy miles just want it to do better off road. It has a hard time now and taks a beatting just want the best of bouth wourlds.
Re: lincon locker? #717183 04/19/06 08:44 PM
Chris_J Offline
<img src="/forums/images/graemlins/evil.gif" alt="" /> Lincon Locker On Pavement. <img src="/forums/images/graemlins/evil.gif" alt="" /> Saw a yota down here the other day that had one driving thought the parking lot of a gas station. Chrip Chrip Chrip every time he turned bet that eats some tires up.
Re: lincon locker? #717184 04/19/06 09:30 PM
DanWheeler Offline
you can switch your diff in an hour?
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: lincon locker? [Re: DanWheeler] #717185 04/19/06 09:43 PM
powerRam50 Offline
i can swap my rear out in a hour...i am welded front and rear and i like.i use my truck for hardcore off road and as a daily driver.
Re: lincon locker? [Re: powerRam50] #717186 04/19/06 09:50 PM
DanWheeler Offline
what do you do for a gasket?
we're talking pull the wheels off, drums, unbolt the axle shaft, pull it out a few inches, drain the fluid, undo all the nuts around the diff, remove the driveshaft all in an hour? wow, you guys are quick.
1986 Montero 2.6l
Re: lincon locker? [Re: DanWheeler] #717187 04/19/06 10:53 PM
Air tools + the correct assortment of sockets <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: lincon locker? [Re: off-roader] #717188 04/19/06 11:01 PM
powerRam50 Offline
exactly.i love air tools.i can swap the front out in less than 2 hours.
for the gasket i just use gasket maker,ultra blue.so far that is one spot i dont leak any fluid.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6376 MB (Peak: 0.7595 MB) Data Comp: Off Server Time: 2026-11-02 08:28:44 UTC
