Jeep won't start. #717313 04/20/06 12:53 AM
W
wyojeeper Offline OP
Hey guys, got a new problem with the jeep.
I left the hard top off the other day and it got rained and snowed in.(6" of snow inside jeep) Now the dang thing won't crank. Battery voltage is good, all connections to starter have been checked. I called the dealership and they told me my aftermarket anti theft electronics probably got wet. There's a small(2 1/2") slim connector mounted under my dash. I never noticed it before. Now it's showing a glowing red light that periodically blinks. Anyone run into this before?
The dealership said I'm looking at 2 to 3 hours of their shop time to remove this anti theft crap from my jeep. Funny thing is, I've owned the jeep for 18 months, and replaced the motor, and this thing's never acted up before.
(Jeep specifics: 1991 yj, 4.0L from 97 xj, 5spd)
Thanks guys.
Re: Jeep won't start. [Re: wyojeeper] #717314 04/20/06 01:22 AM
Tikitgvr Offline
The slim thing under your dash is where they plug the scanner into to read codes lol...your anti theft is in your column around the ignition...sometimes you can disconnect your battery for a while and it will reset itself...or you can see if there is a fuse for it and remove it...that works sometimes..
Re: Jeep won't start. [Re: wyojeeper] #717315 04/20/06 02:08 AM
BigJim Offline
Most of those devices go to the solonoid.. It is kinda under the battery on the firewall... Look there and see if they have cut a soft GREEN wire.. or any other for that matter.. Then they wire into both ends of the wire. Take their wires off and wire the green (or whatever) back to gether again and it should start.
Re: Jeep won't start. [Re: Tikitgvr] #717316 04/20/06 02:18 AM
Sorry Tikitgv, a 91 is OBD1 with the scanner port under the hood. There is a "security card" thing under the steering wheel you might be referring to...
I would just let it dry out some more and wiggle all the connections under the dash and see if that fixes it.
Re: Jeep won't start. #717317 04/20/06 07:11 PM
W
Thanks sunder, You nailed it.
I dried it out overnight, and wiggled the wires, and she fired right up. Now I just have to trace the wires and get this damned thing OUT of my jeep.
Thanks again guys. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Jeep won't start. [Re: wyojeeper] #717318 04/20/06 07:29 PM
Seattlegti Offline
Might fill all the harness plugs with dielectric grease while your in there wiggling things.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6066 MB (Peak: 0.6764 MB) Data Comp: Off Server Time: 2026-06-10 01:30:59 UTC
