3.0 trouble in hollister #717340 04/20/06 03:23 AM
BJWEST Offline OP
a friends motor is wiggin out he has it parked in hollister anyone around thier know the 3.0 enough to take a look at it and give advice. proublems started after he got stuck in deeeeeeep mud. he says it seems like air fule mixture is fluxing. it runs but rpms fluctuate and first gear stalls alot. he lives down south and had to leave truck there he wants someone to look at it before he takes to the dealer and they tell him the only fix is all new everything.
Re: 3.0 trouble in hollister [Re: BJWEST] #717341 04/20/06 06:39 AM
OOP'S Offline
That is the way mine ran when I got water in the air cleaner, it screwed up the AFM that is on top of the air cleaner box. Fix, get a different one!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 3.0 trouble in hollister [Re: OOP'S] #717342 04/20/06 07:18 AM
Cant help with the motor, but if he cant get it started and needs a tow to the dealer I can help for a little fee. I'm about an hour away.
Re: 3.0 trouble in hollister #717343 04/20/06 10:43 AM
5
5150 Offline
Sounds like you hydroplaned the motor, any time water is coming in your doors,it's bad news. Get/build a snorkel
Re: 3.0 trouble in hollister [Re: BJWEST] #717344 04/20/06 12:50 PM
Toy4x Offline
pull the distributor cap and clean out any condensation
Re: 3.0 trouble in hollister [Re: 5150] #717345 04/20/06 02:32 PM
OOP'S Offline
I think you mean "Hydrolocked"!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
David Fritzsche
Roseville, CA
Re: 3.0 trouble in hollister [Re: BJWEST] #717346 04/20/06 08:40 PM
code33 Offline
That happened to me at Hollister once... <img src="/forums/images/graemlins/ignore.gif" alt="" />
Luckily, the motor died before water got into the combustion chamber. I didn't even attempt to crank it over before taking out the spark plugs and turning it over.
Clean out the AFM ASAP or it will corrode.
Re: 3.0 trouble in hollister [Re: code33] #717347 04/20/06 09:04 PM
TexJeff87 Offline
Where is the ECM on the 3.o trucks? Things get wacky when they get wet...
If Mad Max had a 4runner...
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6179 MB (Peak: 0.6999 MB) Data Comp: Off Server Time: 2026-11-03 12:24:23 UTC
