How to change oil and Filter 2006 V6 Tacoma #717440 04/20/06 03:41 PM
Can someone show me how I can remove the upside oil filter on my 2006 Tacoma? Looks like a potential messy oil spill.. I see a drain flange with a hole that runs to a nipple on the left side underneath... I'm assuming if I attact a hose to that nipple that should drain the oil in the direction I want.. Am I correct? seen a few other stories of punching a hole in the top to allow siphon back into the pan or a plastic gallon bag underneath oil filter housing . Is that the only way to avoid oil running everywhere when I crack the seal? any info would be appreciated. thks
Re: How to change oil and Filter 2006 V6 Tacoma #717441 04/20/06 04:22 PM
hupptoy Offline
Yes, I believe that you are supposed to use a hose to route the oil to where you want. You can remove the filter and let it drain right there. The other methods you mentioned are more for horizontal filters on the older trucks.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: How to change oil and Filter 2006 V6 Tacoma [Re: hupptoy] #717442 04/20/06 04:29 PM
Thanks Hupp.. I only have 300 miles so far... 1st change will be at 1k.. I'm going to stick with Castrol 5-30 same oil i use in my 2003 Highlander... I use Fram TG oil filters...
Re: How to change oil and Filter 2006 V6 Tacoma #717443 04/20/06 05:19 PM
azrain Offline
You can slip an piece of hose on the nipple and run the hose to a drain pan if you like.
It's not messy at all, in fact it's very convenient. I put a rag under the little drain hole, spin off the oil filter and flip it up with virtually no spillage at all.
Mike
Re: How to change oil and Filter 2006 V6 Tacoma [Re: azrain] #717444 04/20/06 05:44 PM
Coolist <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: How to change oil and Filter 2006 V6 Tacoma #717445 04/21/06 05:45 PM
Speaking of Transmissions No dip stick for 2006 Tacoma's? Hmm how does one ckeck, add , or monitor the levels??
Re: How to change oil and Filter 2006 V6 Tacoma *DELETED* #717446 06/27/06 04:43 PM
L
Lester Lugnut Offline
Post deleted by Lester Lugnut
Lester
Re: How to change oil and Filter 2006 V6 Tacoma [Re: Lester Lugnut] #717447 06/27/06 11:02 PM
JohnJerk Offline
This thread is a mess. While interesting, the Avalon stuff immediately above has no applicability whatsoever to the new gen taco. And it follows a question about transmission fluid? <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Back to the topic of this thread: I found that a large ziplock bag (a small one will tend to move around too much as it fills with oil), placed immediately under the filter drain nipple works great. The hose seems like too much work to me and it will seep oil in between oil changes. The bag method, while not so enviro friendly, is easy and clean. I am a big fan of the oil filter location on the new gens.
2006 Tacoma Crew Cab 4x4 Auto TRD Off Road
2002 4runner SR5 4x4 79K miles (Sold)
1993 Pickup Ext. Cab 22RE 4x4 82K miles (Sold)
Park City, Utah
Re: How to change oil and Filter 2006 V6 Tacoma [Re: JohnJerk] #717448 06/28/06 06:14 PM
L
John's right. The '06 V-6 Tacoma uses a 1GR-FE motor; the '06 Avalon uses a 2GR-FE.
Digging around, I found that the '06 Tacoma uses a traditional spin-on filter. The '06 Avalon uses a paper insert filter - more of an old design.
I deleted my post. Hope I didn't send too many people down the wrong path.
Lester
Re: How to change oil and Filter 2006 V6 Tacoma #717449 06/28/06 07:18 PM
Denvertaco Offline
get yourself a filter relocation kit and use steel braided lines. Whatever you do don't use the hoses that come with the kit. Put the filter where it is easily accessable and out of harms way. I did that to mine and been thankful ever since. plus you get to use PH8A filters. Sure makes life easy.
03 Double Cab TRD.. ARB, warn winch, OME coilovers, Alcan leafs, Bilstiens, Sky E-locker guard, etc, bla bla bla
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6273 MB (Peak: 0.7329 MB) Data Comp: Off Server Time: 2026-07-11 05:49:17 UTC
