Re: Need input on burnt valve?? Thanks in advance!! 3.0 V6 [Re: Dirtybeerguy] #717541 04/24/06 07:25 AM
Snowtoy Offline
You coul dbe fine driving it for a while, after my burnt valve was diagnosed the last time I drove it for about another 300 miles while I debated rebuilding it myself, paying a shop, or doing the 3.4 swap. I think as long as you are conservative with the mileage you should be o.k. for a while.
Depending on your height you should be able to do remove the top end(not the heades), withoput have to stoop. I myself have 4 hurniated discs in my lower back and was able to removeeverything off the engine except for the heads, those SOB's are heavy if you have a bad back, definately get help with those.
As Rousch mentioned pull the cam gears wioth theheads still attatched to theengine. You will need a large wrench, about 1-1/4 IIRC, and a 2x4 cut at about 18", for the passenger side cam place the 2x4 on the uper A-arm to brace the wrench, for the driver side the 2x4 rests on top of the engine. The other PITA is the removing the crankshaft pulley, I tried using the engine comp. trick, but I couldn't brake ity loose, so I made my own crank shaft holding bar.
With the tear down just pace yourself and you should be o.k., I tried following the manual in steps, but not knowing what each part was by name, I found it eaiser to simply remove and lable the parts as I went. Another trick that is helpful is to use cardboard to put the bolts in, this way I kept them in the order they came out with the part. The tear down went slow doing the extra work, but it made the rebuild a snap, even though it was about 6 weeks from tear down to rebuild, tore my knee up just after pulling the engine down.
My Downey headers were cheaper ordrering them from Central-4wd, than they were from Downey by about $50., I believe they were $360. You will need to order the x-over kit runs about $135, you can build your own, or see what a shop will charge. If you do build your own, have some flanges welded to the headers, once you have tightened the clamp down on them they are hell to get back off.
Re: Need input on burnt valve?? Thanks in advance!! 3.0 V6 [Re: Snowtoy] #717542 04/24/06 04:56 PM
ToyoLoyal Offline
The person who I bought mine from drove it for months with burnt valves on two cylinders. I bought it and fixed it = no extra damage from driving it. Just my experience.
1997 T100 extracab, 3.4L, 5-speed, 169K, 4x4. Love the truck, never buy anything but toyota, I tried it once, most miserable six months of my life.
Re: Need input on burnt valve?? Thanks in advance!! 3.0 V6 [Re: Snowtoy] #717543 04/25/06 02:19 AM
Bent_85 Offline
I'm also in the process of rebuilding my v6. To undo the camshaft sprocket bolts I interlocked and clamped the timing belt with a three of vice grips so the belt would not turn. Then undid the sprocket bolts with a breaker bar. (If youÆre not reusing the T belt.)
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: Need input on burnt valve?? Thanks in advance!! 3.0 V6 [Re: Bent_85] #717544 04/25/06 12:33 PM
Dirtybeerguy Offline OP
You all have been very helpful!! If you ever come towards West Virginia, send me a shout and I would be proud to take you trailin in my neck of the woods. Thanks to each and everyone of you for your thoughts.
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6105 MB (Peak: 0.6839 MB) Data Comp: Off Server Time: 2026-11-18 11:51:50 UTC
