Re: Tacoma coilovers, or coil springs??
#718150
04/23/06 01:52 AM
Or should I get both???!!!
#718151
04/25/06 04:39 AM
Refer to this old post about alternatives to SAW coil-overs: www.4x4wire.com/forums/showflat.php?Board=UBB13&Number=389145There's a ton of info in that thread about those coil-overs that you're considering buying. Don't buy the separate Doetsch-Tech coils. You first need an adjustable coil-over-shock assembly anyway, which would come with springs that are probably better than those.
Jeff 2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids 2007 Tacoma double cab 4x4 - stock
#718153
04/28/06 06:09 AM
No those wouldnt work because the 05's use a different type of strut than the 98-04's...Unless you have an 05, but going off the name 99greenyota I'm assuming you have a 99 <img src="/forums/images/graemlins/lol.gif" alt="" /> Try and find a pair of used sway away, king or fabtech replacement coilovers...From my own personal experience dont try and mix and match parts because it usually ends up being way more hassle and money then if you had just bought the replacements. Here are links to different coilovers that come ready to bolt in with no modification <img src="/forums/images/graemlins/kewl.gif" alt="" /> www.swayaway.comwww.donahoeracing.comwww.allprooffroad.comwww.kingshocks.comwww.fabtechmotorsports.com
1999 Black TRD Prerunner X-Cab V6 3 Revtek Lift 32x11.50 BFG AT 8"x2.5" Sway Away remote resi. coilovers and Total Chaos upper arms sitting in the garage begging to be installed
