Fog Lights
#718349
04/24/06 01:18 AM
I put on these new fog lights on my 89 Xj with the old fog light connecter and they work fine but only if i have the head lights on!!!! I was wondering if you can bypass this so i can just turn them on with the head lights off?
Josh Stefani
Re: Fog Lights
[Re: josh_jeeper]
#718350
04/24/06 01:46 AM
you can run new wires to the fog lights and use a toggle switch,but i want to ask why do you want to.if you have your foglights on you should be using your regular head lights also.the only reasons i can think of to bypass it is if you dont need to use the foglights.also check if they turn off when you hit the high beams.if not something is wired wrong and it should be rewired.
Re: Fog Lights
[Re: josh_jeeper]
#718351
04/24/06 05:37 AM
I don't think you can easily get around it. I would just run a toggle switch to the dash...
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5890 MB (Peak: 0.6435 MB) Data Comp: Off Server Time: 2026-07-13 03:40:34 UTCValid HTML 5 and Valid CSS
