Want rear suspension setup thoughts #718694 04/24/06 08:34 PM
Talon84X4 Offline OP
I'm currently running the ever loved mass produced springs from pro-comp <img src="/forums/images/graemlins/shiner.gif" alt="" />.
Have decided not to go with a buggy leaf set up, reason being this is still my dd, the trails i get to ride have many steap hill climbs and decents so i'm concerned about unloading problems. I've read there's a way to do it, the right way <img src="/forums/images/graemlins/lol.gif" alt="" />, so that you don't run into this problem, but i'd like too keep my rear stock hangers just in-case something doesn't work out right, and a buggy set up would require these to be removed.
I'm planning on going with 63" chevys, all-pro jonny joints 4" back from the stock location and 6" shackles. Along with this i'd like to remove the front torque arm & bracket and put it onto the rear with the arm cut and extended to the crossmember to act as a traction bar.
Would like to get feedback on this plan before I order anything...have been going back and forth on how to set up the rear end of these springs and have settled on this for now.
Any thoughts will be appreciated.
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
'84 PU low & slow
Central Valley Crawlers
Re: Want rear suspension setup thoughts [Re: Talon84X4] #718695 04/24/06 09:09 PM
DirtyHarry Offline
Toyota Moderator
Many people run the Chevys without any sort of traction bar, they springs are quite thick and resist wrapping, but they are so long that they still flex well. I would install them first and then see if you still need a traction bar.
As for the bar itself, I really like Budbuilt's bolt-on design with a shackle. It would provide more flex than using the torque arm (because the shackle works in conjunction with the springs) but still resist axle wrap (because it mounts in two vertically seperated points on the axle).
Re: Want rear suspension setup thoughts [Re: DirtyHarry] #718696 04/24/06 10:23 PM
How about the shackle set up itself, any suggestions there?
'84 PU low & slow
Re: Want rear suspension setup thoughts [Re: Talon84X4] #718697 04/24/06 11:04 PM
TexJeff87 Offline
I have a long one in the stock position. <img src="/forums/images/graemlins/kewl.gif" alt="" />
If Mad Max had a 4runner...
Re: Want rear suspension setup thoughts [Re: TexJeff87] #718698 04/24/06 11:07 PM
What's the angle on that? length?
how well does it work?
I read that you want the angle to be around 50-60 degrees, that 45 wasn't good
'84 PU low & slow
Re: Want rear suspension setup thoughts [Re: Talon84X4] #718699 04/25/06 12:30 AM
4WD22R Offline
Talon, talk to Staceman, he's got a pretty trick setup on his rear axel with a trac bar, used a spare shock mount on top of the diff and another one on the horse collar crossmember and then put something that looked like a draglink between the two of them with joints on either end. This way it runs directly ontop of the DS, dosen't rob any ground clearance and controls the diff moving front to back. I only saw it a couple of times.....we're probally goin out wheelin this weekend so if he can't post up a pic I'll take one for ya.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Want rear suspension setup thoughts [Re: Talon84X4] #718700 04/25/06 01:00 AM
RQF4 Offline
I run a double shackle set up. I just made another set of shackles and attached them to the factory ones. the double shackle works well, allows for lots of drop. I also cut out my old front hangers.
1988 SR5 x-cab 4x4 w/22-re -mod's- custom cold air intake, red top optima, lo-pro bump stops, thorley header, high flow cat, 2.5 exhaust, dynomax muff, chevy springs, procomp shocks .....
Re: Want rear suspension setup thoughts [Re: RQF4] #718701 04/25/06 01:34 AM
I was going to run dual shackles, with the stockers on there now and stock chevies, but don't think i will now because of the unrestricted droop, lack of resistance keeping it close to the frame....again, the unloading fear on steep decents
heard they were the worst in that area <img src="/forums/images/graemlins/frown.gif" alt="" />
'84 PU low & slow
Re: Want rear suspension setup thoughts [Re: Talon84X4] #718702 04/25/06 02:08 AM
4Crawler Offline
I used to run a 7" long shackle w/ 56" rear springs. I now have a 6" + 3.5" double shackle off the stock shackle hanger. I made the top shackle able to bolt to the frame and so far (~3 years) I have yet to unbolt it on- or off-road. Some day I hope to fab up a trac bar and then unbolt the shackle and see what it can do.
Re: Want rear suspension setup thoughts [Re: 4Crawler] #718703 04/25/06 04:53 AM
any reason you havn't used it yet?
'84 PU low & slow
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6400 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-06-09 23:36:17 UTC
