Shifter levers interchangable? #718722 04/24/06 09:36 PM
Myota Offline OP
Are the 5-speed shift levers interchangable from a W56 to a R151?
I know the shift towers(housings) are different but what about the levers with the ball ends?
I have an opportunity to pick up a R151 trans but it does not have the shifters or the housings and I am wondering if the shifters out of my spare W56 will work.
-Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
Re: Shifter levers interchangable? [Re: Myota] #718723 04/24/06 09:56 PM
4Crawler Offline
They seem to be compatible, at least between the L/G/W trannys I have shifters for as well as with the newer trannys in the Tacomas. I combined a W56 shifter base, some parts from an old L-series 4-speed stick and a Tacoma short throw shifter on my W56 gear box:
http://www.4crawler.com/4x4/ForSale/ShortThrowTrannyShifter/index.html
There are a few minor differences in terms of how the shifter is held to the base and the spacing of the pivot pins inside the base.
Re: Shifter levers interchangable? [Re: Myota] #718724 04/24/06 11:13 PM
Myota Offline OP
Anyone else?
Re: Shifter levers interchangable? [Re: 4Crawler] #718725 04/25/06 01:20 AM
kyle-22r Offline
am i correct in assuming that all you had to do was scrounge the cup off a G tranny to be able to install the short throw shifter? i'd be interested in putting on in my '91...
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Shifter levers interchangable? [Re: kyle-22r] #718726 04/25/06 02:05 AM
4Crawler Offline
The W56A shifter uses a bolted down retainer while the L-, G- and later W- shifters use the spring loaded cup. I had to get the spring loaded cup off of another shifter so that I could transfer it to the short throw shifter stick, which comes without such a cup. There was no way to remove the retainer off the W56A shifter without destroying the shifter and then it was going to be eqaully as hard to get it onto the short throw stick.
Then you need to build a spacer plate for the short throw. Since it is designed for a Tacoma shifter, the existing spacer does not fit.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6064 MB (Peak: 0.6870 MB) Data Comp: Off Server Time: 2026-07-14 18:33:38 UTC
