Steering Components #718934 04/25/06 07:28 PM
P
parshal Offline OP
Does it make sense to change out the tie rods when I rebuild the front axle? This is an '83 22r pickup. The steering is a little loose and I figured I'd swap those at some point (which I've never done before) and figure it might as well be at the same time.
I've been looking for info on replacing the tie rods but haven't found much other than the FSM. What simple things would I want to replace to help tighten the wandering? Idler arms? Pittman arm?
Re: Steering Components [Re: parshal] #718935 04/25/06 07:50 PM
kyle-22r Offline
the loose steering means that the drag link may need to be adjusted. unless the tie rod ends themselves are sloppy, you can leave them be.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Steering Components [Re: kyle-22r] #718936 04/25/06 08:55 PM
P
parshal Offline OP
How is that adjusted? I see it in the FSM but only see installation and removal.
I just figured due to the age that the tie rod ends could use replacing. It looks like I'm halfway there once the axle is apart.
Re: Steering Components [Re: parshal] #718937 04/25/06 09:21 PM
4Crawler Offline
Screw slots in the ends of the draglink that can be cranked in to tighten. I made a special tool to crank mine down when I ran stock steering:
Re: Steering Components [Re: 4Crawler] #718938 04/25/06 10:57 PM
MnMsToY Offline
Check your front U bolts too. My steering was wondering some. A friend pointed out the U bolts were loose. I had changed out my front leaf springs and never did go back and recheck them after wheeling about three months. I thought it was time for a total rebuild. Never would of thought that loose U bolts was the problem.
MIke
1980 Toy, Dovetail, Chevy 60/14, 5.13 gears "Wheeling isn't cheap anymore"
http://www.texas4x4.org/gallery/MikesToyota
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6053 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-06-13 10:50:59 UTC
