tie rod flip #719043 04/26/06 08:29 AM
steven c Offline OP
Just did a torsion bar lift, using Darlington diff drop brackets on my 94 amigo. Noticed slight bump steer with this set up. I suspect because the tie rod angle is no longer parallel to the ground. I was wondering if it would be possible to flip the tie rods from under the steering knuckles to the top using a kit similair to the one found on:
www.rock-equipment.com
Any Input?
Thanks
Re: tie rod flip [Re: steven c] #719044 04/26/06 08:53 AM
Rodeo Guy Offline
Your answer can be found in the fourth result from a search of "+tie +rod +flip". I could easily give you the link, but that wouldn't teach you to search. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: tie rod flip [Re: Rodeo Guy] #719045 04/26/06 12:48 PM
strawmyers Offline
Isuzu Moderator
Just for safety purposes, I'll say don't do it. As for the "why"... well, that search mentioned above will make all things clear <img src="/forums/images/graemlins/wink.gif" alt="" />
Sean Strawmyer
Re: tie rod flip [Re: strawmyers] #719046 04/27/06 06:45 PM
CPOM Offline
In IFS, the mounting point is taken into consideration to keep you from steering when the wheel moves. Moving the TRE to a different spot will change that geometry.
This is not an issue in a solid axle as the TRE doesn't pivot relative to the axle/wheel.
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6006 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-22 02:42:44 UTC
