Page 1 of 4 1 2 3 4
Anyone put a fully shifted case in a 2nd gen? #719048 04/26/06 12:58 PM
Bigpoppax2 Offline OP
I'm going to try to put a fully shifted t-case out of a 94 Passport that has Teras in it (I know they are right I put them in)
Anyway I was just curious if anyone has done it. Going from a front back type shifter to a front back and side to side.
I know it will bolt on, I'm just curious if I will be able to shift without interior modifications.
Joe
Re: Anyone put a fully shifted case in a 2nd gen? [Re: Bigpoppax2] #719049 04/26/06 03:35 PM
Smiley Offline
I was gonna open with some sort of Sawz-All joke, but it was too easyà <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Joe - If youÆre concerned with shifter clearances, your best bet would probably be to compare your 2nd Gen Shifter Boot with a 1st Gen Shifter Bootà if theyÆre the same, then youÆre good to goà if not, then maybe you could modify your 2nd Gen to accept a 1st Gen Boot.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Anyone put a fully shifted case in a 2nd gen? [Re: Bigpoppax2] #719050 04/27/06 04:20 AM
slappy Offline
I'd like to see where you're going with this Joe...are you going to have to mess with the SOTF system at all?
-john
99 Rodeo 3.2L 4WD
Re: Anyone put a fully shifted case in a 2nd gen? [Re: slappy] #719051 04/27/06 01:30 PM
Well yes and no. I'm going to make it be turning all the time seeing as I have manual hubs it won't really be serving any purpose anyhow.
I just want to get rid of things that can cause problems, like shifter motors and vaccum disconnects. I just want a fully shifted case that just happens to have the Tera gears in it.
Getting rid of the 4wd button also gives me one more spot for the rear ARB I'm planning on down the road.
Joe
Re: Anyone put a fully shifted case in a 2nd gen? [Re: Bigpoppax2] #719052 04/27/06 03:32 PM
slappy Offline
I like where you're headed. I know I've had a few bugs with my SOTF, and have thought of what to do with it and how how to bypass it, but it never occurred to me to put in a fully shifted case.
Wish I could give you better help with this.
-john
99 Rodeo 3.2L 4WD
Re: Anyone put a fully shifted case in a 2nd gen? [Re: slappy] #719053 04/29/06 05:34 PM
Well after speaking with Jerry Lemond it seems it should be a direct bolt in. The Rodeos overseas don't come with shift on the fly, so they come with a fully shifted case in the second gen trim.
So all I need to do is make a plate with a few rods to hold the shift fork in the right position to hold the collar for the axle disconnect, in the connected position.
Then see if I have the wiring near the tranny for the older style 4wd indicator switch in the t-case.
Joe
Re: Anyone put a fully shifted case in a 2nd gen? [Re: Bigpoppax2] #719054 05/01/06 03:48 AM
Rodayo Offline
Excuse my ignorance, but what is a fully shifted transfer case?
1996 Rodeo - 3.2L, 5sp., ARB Bull Bar, Rancho 9000x, Eclipse sound
2004 Rodeo - 3.5L DI, Auto
Re: Anyone put a fully shifted case in a 2nd gen? [Re: Rodayo] #719055 05/02/06 03:50 AM
Well to put it best, you shift the transfer case yourself instead of depending on a shift motor and vaccum disconnects.
For me it's getting rid of stuff that can fail.
Joe
Re: Anyone put a fully shifted case in a 2nd gen? [Re: Bigpoppax2] #719056 05/02/06 09:18 AM
StinkBug Offline
On the older trucks the transfer case was shifted entirely via a lever on the floor. On the newer models there is a pushbutton on the dash that engages the front axle vaccuum disconnect and the 4wd shift rail in the t-case. The lever only operates the hi-lo range change.
Dallas
[color:"blue"]Crew Chief, RedBull RockCrawling Team [/color]
[color:"red"]StinkyFab Custom Metal Creations[/color]
Project StinkBug
Re: Anyone put a fully shifted case in a 2nd gen? [Re: StinkBug] #719057 05/02/06 12:49 PM
A
anubis Offline
where you going to run the extra lever to Joe. seems like that area is rather cluttered to begin with. I am sure you will come up with something nice just wanted to get a sneak peek
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6408 MB (Peak: 0.7650 MB) Data Comp: Off Server Time: 2026-05-25 19:00:47 UTC
