Page 1 of 4 1 2 3 4
Front Bumper Project #719402 04/28/06 03:57 AM
Zubicon Offline OP
Well I'm back, it took me awhile to get started on the front bumper but here's what occurred so far.
Main plate: 1/4 inch thick that the winch will be mounted on that will be bolted directly to the frame. No welds are between the winch and mounting surface. That and the fact that it's 1/4" is what sets it apart from Hansen's, Advance Engineering, Fab Four, and M.O.R.E. This is the main carcass that everything else will be build around. Measure three times before you drill. I had to drill 4 holes for mounting it to the frame and 4 to the winch. 3 holes were just a tad bit off so I had to refill the holes (the great thing about welding) and redrill. Well when you are drilling on the stock metal with a tensil of 45,000 lbs the bit goes through like butter, but when you are drilling through a weld that was done with 34 wire the tensil goes up to 72,000 lbs. I drilled for over an hour and didn't make a dent so I had to pull out the plasma cutter to punch through it, then finish off the hole with the drill bit. Anyway the holes are now 100% perfect.
Just checking the fitment off the fairlead mounting plate to see what the relationship of where the OME fog lights and side panels will go.
Stage 3 mock up: mounting plate, fairlead mount, and winch:
Stage 4: lots of poster board and lots of hot glue.
now you can probably get a rough idea of what it will look like. I have all my master templates of poster boards cut, they'll be transferred to master plates of 16 guage steel in the next week, then the welding begins. The only thing to still figure out is what bar(s) I'm going with, what lights, and how many of them that I'm going to build....hint
Re: Front Bumper Project [Re: Zubicon] #719403 04/28/06 06:23 AM
Berkeley Offline
Jeep Moderator
I like it... looks like good work. Love the poster-board mockup, too. Much easier to make mistakes with paper!
Re: Front Bumper Project [Re: Berkeley] #719404 04/28/06 05:16 PM
Zubicon Offline OP
Thanks, the poster board mock up has saved me numerous hours over time. I got this one completed and realized I boxed in where my bolts mounted it to the frame. Duh! So I had to revise it.
Re: Front Bumper Project [Re: Zubicon] #719405 04/28/06 06:46 PM
That looks really professional. I like the bit of engineering you threw in. Could you make plans for your mount?
Re: Front Bumper Project #719406 05/29/06 07:17 PM
Zubicon Offline OP
Here's the finished product. The first Front Bumper, dubbed "The Mine Sweeper" of Creepy Crawler Concepts & Creations.
Re: Front Bumper Project [Re: Zubicon] #719407 05/30/06 01:31 AM
BigJim Offline
Lovely!
Re: Front Bumper Project [Re: BigJim] #719408 05/30/06 08:50 PM
tcoff Offline
SWEETTTTT!!!! thats awsome. What kind of paint did you use?
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
Re: Front Bumper Project [Re: tcoff] #719409 05/31/06 02:06 PM
Zubicon Offline OP
it's not paint, it's Rhino Lining. I would highly discourage the use of it. It peels right off like a banana.
Re: Front Bumper Project [Re: Zubicon] #719410 05/31/06 02:54 PM
cuervo25 Offline
yup when painting something like that you should use por-15,or if you want a textuure type paint use hammerite.they are both highly resistant to rust,and chipping.
Re: Front Bumper Project [Re: Zubicon] #719411 05/31/06 04:31 PM
Zubi, how did you prep the metal before applying the Rhino? If you did a Zylol washdown the Rhino should have stuck nice and tight.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6362 MB (Peak: 0.7612 MB) Data Comp: Off Server Time: 2026-10-21 18:53:31 UTC
