Page 1 of 4 1 2 3 4
Venting Engine Compartment #719442 04/28/06 04:44 AM
Mississippi_Blue Offline OP
It has been suggested that I vent the engine compartment with a couple of air scoops (one over the carb & the other on the opposite side).
Where is a thread I can refer to? I've got a body shop connection and really need to do this before I go out on the trails again.
'87 RAIDER, rebuilt & modified, "Bleaux"
'87/'88 Mitsu Montero SWB, parts truck.
'03 Mitsu Montero Sport ES - my "driving Mz Daisy" station wagon.
Re: Venting Engine Compartment [Re: Mississippi_Blue] #719443 04/28/06 06:16 AM
Chris_J Offline
Get some vents from JCWhitney should cool ya down. You can also unplug the a/c compressor and just run the condensor fan.
Re: Venting Engine Compartment [Re: Mississippi_Blue] #719444 04/28/06 06:42 AM
LRJ4x4 Offline
Check your fan clutch
Re: Venting Engine Compartment [Re: LRJ4x4] #719445 04/28/06 12:59 PM
New fan clutch ordered. It was weak, but I still want to vent. The engine compartment got so hot on my last trail ride the gas was vaporizing!
Re: Venting Engine Compartment [Re: Mississippi_Blue] #719446 04/28/06 02:49 PM
If the fan clutch is sound, the engine compartment vents very well as it is. I suspect that the carb is getting heated by the coolant in the manifold, which is overheated by the lazy fan.
Re: Venting Engine Compartment [Re: fasteddy] #719447 04/28/06 03:50 PM
BobShaw Offline
You can open up the inner wheel wells to vent the engine.
If you have an older radiator, have it rodded. Cleaning just don't do the job. Been there and done that. I added a switch to the AC fan too.
Re: Venting Engine Compartment [Re: Mississippi_Blue] #719448 04/28/06 07:10 PM
W
wyleone Offline
The fan is weak but the coolant was not very hot. The guage (working properly) was only halfway up. The heat is not leaving the engine compt. EVERYTHING under the hood was untouchable, including the hood. The fan can be felt blowing up ward but as soon as you put your can approx where the t-stat is you cannot feel andy air movement. The fan blades could be cracked since some semi deep water was encountered by the present owner, whoever that is. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: Venting Engine Compartment [Re: wyleone] #719449 04/28/06 07:57 PM
LandRaider Offline
Whats up Wyleone? long time no see man.
Re: Venting Engine Compartment [Re: wyleone] #719450 04/28/06 08:19 PM
LRJ4x4 Offline
Something is up, I run my truck in 110 degree heat and it never gets that hot.
Maybe the water pump is shot? It's hard to belive that everything under the hood is baking and the guage is only at the half mark. <img src="/forums/images/graemlins/confused.gif" alt="" />
The jeep on the cover of 4wheelparts mag has a few fans bolted right on the hood, ugly as hell but I'm sure it cools. So I wonder if the fan is pulling air up or pushing air down ? Hot air rises
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Venting Engine Compartment [Re: LRJ4x4] #719451 04/28/06 08:45 PM
CapnCrunch Offline
I also wonder how it does in winter. Even if the fans are turned on by manual switch there are still gaping vents that will hinder its ability to warm up and stay warm in winter. If I put vents in my hood I'd want to make sure I could close them off as needed. Otherwise, I'd never warm up in winter. <img src="/forums/images/graemlins/scared.gif" alt="" />
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6418 MB (Peak: 0.7650 MB) Data Comp: Off Server Time: 2026-05-29 23:49:58 UTC
