Page 3 of 4 1 2 3 4
Re: Venting Engine Compartment [Re: Jamez] #719462 04/30/06 03:51 AM
jeepdriver Offline
I do not know if this will help you, but a friend of mine scored a spare hood for his Jeep Cherokee from the local wrecking yard and had louvers punched in it, just like on a gym locker. He had a shop that builds ambulance bodies do it, as they louver the hoods of the ambulances to let the excessive heat out.
Too many 4x4's, not enough time or money
Re: Venting Engine Compartment [Re: LRJ4x4] #719463 04/30/06 03:58 AM
Mississippi_Blue Offline OP
Yes the bottom part that the tube connects to. The tube btw is the heat riser for when the engine is cold. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Okay everyone know's I'm a lover not a mechanic? Sh*t! I'm about to sell my original GenI [such language]
good grief <img src="/forums/images/graemlins/lol.gif" alt="" />
'87 RAIDER, rebuilt & modified, "Bleaux"
'87/'88 Mitsu Montero SWB, parts truck.
'03 Mitsu Montero Sport ES - my "driving Mz Daisy" station wagon.
Re: Venting Engine Compartment [Re: Mississippi_Blue] #719464 04/30/06 05:38 AM
W
wyleone Offline
OK uncomplicate the whole mess.....One thing, replace the fan clutch and inspect the fan blade when you are doing that. Do nothing else till that is complete. Do not install the vents, do not install the exaust shield (yet).
Only one thing failed at this point and that has been identified. Replace it, and re-evaluate the situation.
Re: Venting Engine Compartment [Re: wyleone] #719465 04/30/06 05:20 PM
That I can do.
Re: Venting Engine Compartment [Re: Mississippi_Blue] #719466 04/30/06 07:24 PM
Monty Offline
when I'm in 4l and just crawling along, I pop the hood so it's just on the safety catch. That helps to get some fresh cooler air under the hood
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: Venting Engine Compartment [Re: Monty] #719467 05/01/06 05:32 PM
8
89IsMine Offline
when I'm in 4l and just crawling along, I pop the hood so it's just on the safety catch. That helps to get some more fresh cooler air under the hood
Safety catch? Your Monty has a safety catch? <img src="/forums/images/graemlins/scared.gif" alt="" />
Not to hijack the thread, but my '89 Raider does not have a safety catch on the hood... should it? <img src="/forums/images/graemlins/frown.gif" alt="" />
Eric W.
Re: Venting Engine Compartment [Re: 89IsMine] #719468 05/01/06 06:09 PM
CapnCrunch Offline
It should. It's nothing special.....same thing that most every vehicle nowadays would have. You pull the hood release and that releases the primary latch. Then, when you go up front and reach a finger or two under the hood to release that lever so you can open the hood the rest of the way.....that's the safety catch.
Mine's an '88 and it has it.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Venting Engine Compartment [Re: 89IsMine] #719469 05/01/06 06:10 PM
Yes it should. When you release the hood from inside the cab, you should have to push a lever under the hood to open it. This lever is the safety catch.
Re: Venting Engine Compartment [Re: CapnCrunch] #719470 05/01/06 06:10 PM
oops. you win! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Venting Engine Compartment [Re: off-roader] #719471 05/01/06 07:50 PM
CapnCrunch Offline
ha-HAAA!!!
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6465 MB (Peak: 0.7721 MB) Data Comp: Off Server Time: 2026-05-29 21:10:05 UTC
