Sammy questions
#719826
04/30/06 04:30 AM
OK here's what i got i got a Sammy body an frame really cheap Ive got a d25for the front an a d44 for the rear both with 5.88 gears what i need to no is can i make a jeep 258 i6 fit into a Sammy i was wanting to use the motor an tranny an t case the axles are out of a 54 cj3b an the motor tranny an t case is out of a 79 cj5 I'm going to stretch the frame also thx for the help
1988, Dodge Raider, 2.6 5 speed, 4x4, 33in interco ltbs
Re: Sammy questions
[Re: goblin79]
#719827
05/01/06 07:30 PM
I imagine you will end up doing a body-off frame re-engineer to get it all to fit. But I don't have any experiance with those particular parts. Sorry I can't be more help.
Bill ---------------------------- God Forgives, Rocks Don't...
Re: Sammy questions
[Re: Billjohn]
#719828
05/02/06 04:03 AM
you can make anything work but the 258 is a pretty long engine the only way i see you doing it is streching it in the front and rear tube clip the front and a flat bed in the rear and then the tranny hump will have to be cut all to hell. i suggest getting a 1.6 16v efi and keep the tranny and put a lower gear set in the sammy t-case then do a jeep eater yj spring conversion with your axles but if you just want to build a little off road toy out of the stuff you already have laying around then fab fab fab but i think with the engine tranny and t- case you have you will end up with a rear driveshaft around 6"long
if it don't fit, force it if it breaks, it needed to be replaced anyway
Re: Sammy questions
[Re: blevcom21]
#719829
05/03/06 05:13 AM
IT WILL BUT IM GOINGTO STREACH THE FRONT AN REAR U SAIDIT FAB FAB FAB LOL sorry bout the caps just seen it
Re: Sammy questions
[Re: goblin79]
#719830
05/03/06 11:37 AM
dont forget to take and post plenty of pics and post them so we can see the progress and watch the lil zuk grow
Re: Sammy questions
[Re: blevcom21]
#719831
05/03/06 06:03 PM
will do i just found out how much the Sammy is going to cost me hahaha its free so ill have just labor an maby a few smaller parts to buy so its going to be really cheap for me to do
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6077 MB (Peak: 0.6778 MB) Data Comp: Off Server Time: 2026-06-17 10:43:07 UTCValid HTML 5 and Valid CSS
