electrical problem #719910 04/30/06 07:49 PM
cmrg63 Offline OP
I have a 98 gmc jimmy with a 4.3 & automatic transmission. This vehicle has a problem with the electrical system. The problem has to do with the transmission, the dash gauges, the key switch, and the trasmission shifter lever. When this vehicle acts up the check eng light comes on. the lights on the dash go out and the fuel gauge drops to empty. The transmission is slugish. The key will not come out of the ignition switch when shutoff.When the key is on the eng. is off if you push the button on the trans. shifter the lights come on and the fuel gauge starts to work. When you start the vehicle, messing with the shifter button dose'nt do anything . CODES : PO 740 TORQUE CON. CLUTCH CIRCIT FAILURE , PO 753 SHIFT SOL. 1 ELECTRICAL, PO758 SHIFT SOL. 2 ELECTRICAL, PO 1860 TORQUE CON. CLUTCH PWM SOL. CIRCUIT. PO1870 TRAN. COMPONENT SLIPPING. I am thinking this is a ground problem if some one has seen this before and knows anything about this i would sure like to know how to fix it. thank you.
Re: electrical problem [Re: cmrg63] #719911 05/03/06 03:47 AM
52degrees Offline
I'll get a schematis off the computer tomorrow or the day after and see if I can find a common ground or something of that nature for you.
Clay
KG6VNX
Re: electrical problem [Re: 52degrees] #719912 05/05/06 03:00 AM
cmrg63 Offline OP
Thanks But i got it fixed. It is the ign. switch. There is a tsb on this problem.
Re: electrical problem [Re: cmrg63] #719913 05/07/06 09:56 PM
52degrees Offline
Good. I looked up the grounds common to your problems, but they were pretty diverse. Sorry I didn't get back to you sooner.
Clay
KG6VNX
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6001 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-07 08:06:18 UTC
