Bucket of bolts? #720023 05/01/06 12:24 AM
BryanBosch Offline OP
My 1998 Rodeo LS 3.2L V6 4X4, after 100k really sounds like a bucket of bolts now. When driving on semi-rough pavement and espeically when cornering on rougher pavement, it sounds like the left front suspension has a loose part, like a ball joint clanking around or something, but I've checked and everything seems tight. Is this common to the gen II Rodeo and if so, what's the fix? Ideas?
Re: Bucket of bolts? [Re: BryanBosch] #720024 05/03/06 08:54 AM
Bansil Offline
Check your wheel bearings and shock on the side making the noise.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Bucket of bolts? [Re: Bansil] #720025 05/03/06 06:09 PM
lttlbddy Offline
Check: ball joint, control arm bushings, steering components and those wheels bearings.
Re: Bucket of bolts? [Re: BryanBosch] #720026 05/03/06 06:19 PM
P
prong Offline
I have a bad shock bushing that sounds like a 'bucket of bolts', the metal sleeve is rusted/worn out to a larger diameter and makes alot of noise hitting the bolt, especially now that its warm enough to drive with the windows down <img src="/forums/images/graemlins/smile.gif" alt="" />
1991 Trooper 2.8, 5spd - waiting for a different frame and tranny
1992 Rodeo 3.1, 5 spd - 1 inch between me and the headliner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5999 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-06-23 21:19:37 UTC
