Problem with 4WD and A.D.D Controls #720108 05/01/06 02:08 PM
Bratik Offline OP
I am having problem with engaging/disengaging 4WD system.
I have a Limited 2000 4Runner that has push in button on the 4wd selector stick. When I pressed it, the lights on the dash that shows 4wd system engaged are blinking. Unlocking the button or moving lever to 4wd or 2wd position
are not doing anything. Now I am half way into 4wd. I feel that the front wheels have engaged into 4wd mode, where I currently stuck. Please help me resolve this issue before EC4RJ event in 2 weeks.
Re: Problem with 4WD and A.D.D Controls [Re: Bratik] #720109 05/02/06 02:18 AM
DRTDEVL Offline
Check the electrical connectors to the transfer case. Some members have found water/corrosion inside, inhibiting the system from doing it's job.
Clean them out, and apply dielectric grease before plugging them back in, and you should *hopefully* be back in business!
Re: Problem with 4WD and A.D.D Controls [Re: DRTDEVL] #720110 05/03/06 12:48 PM
Bratik Offline OP
Thanks man, I'll try this this weekend, hopfuly this will fixe the problem.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5948 MB (Peak: 0.6483 MB) Data Comp: Off Server Time: 2026-06-15 10:26:06 UTC
