Problem with 4WD and A.D.D Controls
#720108
05/01/06 02:08 PM
I am having problem with engaging/disengaging 4WD system. I have a Limited 2000 4Runner that has push in button on the 4wd selector stick. When I pressed it, the lights on the dash that shows 4wd system engaged are blinking. Unlocking the button or moving lever to 4wd or 2wd position are not doing anything. Now I am half way into 4wd. I feel that the front wheels have engaged into 4wd mode, where I currently stuck. Please help me resolve this issue before EC4RJ event in 2 weeks.
Re: Problem with 4WD and A.D.D Controls
[Re: Bratik]
#720109
05/02/06 02:18 AM
J Roll Me Over
Check the electrical connectors to the transfer case. Some members have found water/corrosion inside, inhibiting the system from doing it's job.
Clean them out, and apply dielectric grease before plugging them back in, and you should *hopefully* be back in business!
[Re: DRTDEVL]
#720110
05/03/06 12:48 PM
Thanks man, I'll try this this weekend, hopfuly this will fixe the problem.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5936 MB (Peak: 0.6471 MB) Data Comp: Off Server Time: 2026-06-15 10:38:23 UTCValid HTML 5 and Valid CSS
