AC clutch Wire no voltage? #720120 05/01/06 03:39 PM
chuckelbarry Offline OP
I cant get voltage at the AC pully clutch. the AC dash switch lights up. the manaul says the AC has a 20 amp fuse but i cant find it under the hood or kick panel. Oh the truck is a 88 v6 runner. where is this dam fuse?
Re: AC clutch Wire no voltage? [Re: chuckelbarry] #720121 05/01/06 03:44 PM
stock87 Offline
Drop your glovebox and look to the left inside the void. There are two fuses there.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: AC clutch Wire no voltage? [Re: stock87] #720122 05/02/06 04:46 AM
OOP'S Offline
Maybe it is low on Freon, they will not energize if it is low or empty.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5944 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-06-07 06:55:55 UTC
