Leaking power steering fluid #720787 05/03/06 08:53 PM
allsierra123 Offline OP
My truck is leaking fluid from the top of the steering box.There is a big nut on top and four smaller ones just below that.It looks like its leaking from the big nut in the center of the top.I looked at the repair manual and it didnt look like there was a gasket or anything in there?Is that the case is it repairable or do I need to replace the whole unit?
91 Mitsu Montero RS LWB PENDING
88 Cherokee Lifted and modded heavily. FOR SALE
91 vanagon syncro 1.9 TD SOLD
04 Suzuki Aerio Commuter SOLD
90 mits mighty max,v6 SOLD
94 Mits Diamante LS. Stock. TOTALED
71 VW Baja Bug SOLD
Re: Leaking power steering fluid [Re: allsierra123] #720788 05/04/06 03:43 AM
I think KevinC fixed that with an Oring, maybe a mitsu kit?
Re: Leaking power steering fluid [Re: fasteddy] #720789 05/04/06 07:12 AM
DanWheeler Offline
#12 - O-ring.
Could also be the adjusting nut (#10) or the bleeder screw (#5) Is it coming out from around the square thing (#7)
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: Leaking power steering fluid [Re: fasteddy] #720790 05/04/06 07:45 AM
Kevin C Offline
If its leaking from the nut there is a factory kit that screws on top of the adjuster nut to seal it.
My quick and dirty fix is to use loctite gasket maker #518 on the threads and under the nut.
Just dont mess up the adjustment by turning the screw, just loosen the nut, clean the parts and apply the sealer. Tighten the nut back down and the leak should stop.
Kevin
Re: Leaking power steering fluid [Re: Kevin C] #720791 05/04/06 02:01 PM
conner Offline
I used a copper washer from a brake hose.
Conner
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: Leaking power steering fluid [Re: conner] #720792 05/04/06 09:27 PM
It looks like it is leaking from #8 the center nut.But it could possibly be leaking from the square thing as well.Looks like I can take all of that apart without messing up to much correct?
71 VW Baja Bug SOLD
Re: Leaking power steering fluid [Re: conner] #720793 05/04/06 09:40 PM
Kevin C Offline
The washer is good for sealing the nut... I had fluid coming up the threaded section on screw #8.
This area is where most of the top of the box leaks come from. I would try fixing the nut before taking anything else apart.
Kevin
Re: Leaking power steering fluid [Re: Kevin C] #720794 05/01/08 03:58 AM
Kevin C Offline
Old post that is still current...
Kevin C
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6251 MB (Peak: 0.7072 MB) Data Comp: Off Server Time: 2026-05-27 21:23:41 UTC
