99 4Runner sometimes stalls out when idling in traffic #720967 05/04/06 07:20 PM
jataga Offline OP
For the past few months, my 4Runner has been idling normal when I come to a stop but after about 20-60 seconds, it starts to fluctuate and will sometime shut off. I've done a throttle body cleaning, ran fuel additive, and ran a couple of tanks of premium gas but still the same thing.
Basically it idles at around 700 RPMs or around that normally. When it starts to act up, it drops to around 450 up to 500 down to 450, up to 550 down to 400 and then dies. These numbers aren't exact but give or take 50. If I tap the gas when it is fluctuating, it goes back to normal for a minute or so. Of course when i am driving, everything is fine.
I have about 174,000 miles on my 4Runner
Replaced plugs at 150,000
Replaced coil packs at 146,000
Timing belt was replaced at 74,200 - I wonder if this is the problemà
oil changed every 3000 - i know this has nothing to do with it.
Any help will be appreciated!
99 Limited 4Runner 4WD
ARB front Bumper Kennesaw rear bumper
WARN 9500 Winch
Hella 4000s
Re: 99 4Runner sometimes stalls out when idling in traffic [Re: jataga] #720968 05/05/06 03:02 AM
Sounds like you may have a possible vacuum leak.
Re: 99 4Runner sometimes stalls out when idling in traffic [Re: jataga] #720969 05/05/06 03:48 AM
stock87 Offline
Check for any cracks in the air hoses going to the throttle body. The engine may be flexing just enough on the mounts to let some unmetered air in, allowing it to lean out just enough to die.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: 99 4Runner sometimes stalls out when idling in traffic [Re: stock87] #720970 05/05/06 01:32 PM
jataga Offline OP
Thanks for giving me some things to look for. I appreciate it!
WARN 9500 Winch
Hella 4000s
Re: 99 4Runner sometimes stalls out when idling in traffic [Re: jataga] #720971 05/07/06 09:39 PM
TRDatVT Offline
I am having the same sort of problem on mine... 1999 110,000 miles. I cannot seem to find a vacume leak and i am holding boost well. The idle when i initally start the truck up cold is very erratic as well until it starts to warm up some and then its fine.
1999 4-runner
TRD Supercharger, 5 speed, 2 inch pulley, Dual 2.5" exhaust, AEM Brute Force Intake, Supra Injectors
Re: 99 4Runner sometimes stalls out when idling in traffic [Re: TRDatVT] #720972 02/20/07 11:03 PM
jataga Offline OP
Sorry for the late response. The problem was a bad THROTTLE POSITION SENSOR. after that was replaced, the problem was gone!
I hope this helps others out there with the same problem.
WARN 9500 Winch
Hella 4000s
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6119 MB (Peak: 0.6817 MB) Data Comp: Off Server Time: 2026-05-29 14:38:13 UTC
