Bouncy rear end #721078 05/05/06 03:45 AM
kashlak Offline OP
I lifted my truck about 3.5 inches with the o.m.e 919s and front torsion crank, im still running the stock shocks because i have allready spent enough money on the coils,tires and alighnment. the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> end bounces pretty bad over expansion joint and what not, so im guessing that most likely the stock shocks are some of the problem and the other being the heavy duty coils. Im just looking for confirmation before i tell the wife i need to spend more money on my truck. I know guys are running the 919s and even Bansil running the 929s.
Thanks for any help.
2002 RODEO LS 3.2 4x4
32" KUMHO MTs
O.M.E. 919 PROCOMP ES9000
K&N FILTER
Re: Bouncy rear end [Re: kashlak] #721079 05/05/06 05:18 AM
holger Offline
for 919s coils, the stock shocks are way too short. You need long Ranchos, 9000X 99179, for the rear.
Oleg
Deceased Rodeo'02 4WD.
Re: Bouncy rear end [Re: holger] #721080 05/05/06 09:32 AM
A
anubis Offline
you can even go with the pro comp shocks. There is no need to spend the extra money on the 9000x's. I run the pro comps and they have a far better ride than the stock anyday
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: Bouncy rear end [Re: anubis] #721081 05/05/06 02:51 PM
ducktrooper Offline
What/s the difference in specs or peformance from 912's to 919's?
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: Bouncy rear end [Re: ducktrooper] #721082 05/05/06 05:10 PM
holger Offline
919 are the longest coils for Isuzu, 912 shorter, 913 are the shortest. As for the coil rates, I suppose they are very close. I did not have 912, I had 913 and now I have 919.
The length difference between 919 and 913 is dramatic, 919 are about 50% longer (when uncompressed).
Oleg
Re: Bouncy rear end [Re: holger] #721083 05/05/06 06:24 PM
chasespeed Offline
Yeah, the 919 is a LONG shock..actually had to undue the uppers and the shocks to get them in... And, there was NO WAY, the sway bar was getting hooked back up...
I am also running the 2 inch spacers on top of those...
I need a longer shock in the rear, ON TOP of the longer shock thats in there now....
But, to answer your question, yeah, spend money on the shocks, it will make a world of difference...
Chase
Chase
Re: Bouncy rear end [Re: chasespeed] #721084 05/05/06 07:20 PM
holger Offline
Chase I have a similar setup - 919+2" spacers.
Even the Ransho 99179 shocks were not long enough ! I had to install 99017. With them, it's perfect: the upper travel is exactly the same as the downtravel (I have bent links which helps).
Oleg
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6175 MB (Peak: 0.6921 MB) Data Comp: Off Server Time: 2026-10-26 03:51:17 UTC
