Re: I fear the worst [Re: hayhauler] #721232 06/16/06 07:07 PM
DaPeach Offline
They replaced the CPS, and coil pack. The engine relay was making noise, so they replaced it. They tell me it has fuel but no spark. Is there anything else they should check?
CPS?
From what I've learned over the past few months w/ mine & the help of Axeman here is the only things that can cause a "no spark" situation are the ECM (computer located against the firewall in the passenger compartment), bad coils, camshaft position sensor (located on the left back of the head) , crankshaft position sensor (located under towards the rear of the block on the left side).
Check those connections first. But if it ran going in, they need to make it run coming out.
-Karri
2006 Jeep Liberty
1999 Sportage EX - for sale
....______o_o
.../_l l__\____\
..|--l l__----[]\|/[]
.....................oo
=( )_)----( )_)--)_)
Re: I fear the worst [Re: DaPeach] #721233 06/22/06 03:27 AM
hayhauler Offline OP
CPS = Cam Position Sensor
But that wasn't the problem, it turns out the problem was a bad ground post on the starter. It wasn't too expensive to fix.
'95 Sportage 4x4 5speed SOHC bone stock, 200,000 miles and counting.
The KIA isn't as powerful as the dually, but it sure is easier to park.
Re: I fear the worst [Re: hayhauler] #721234 06/22/06 04:16 AM
DamKia Offline
Kia Moderator
Good to hear that it was simple. Not too bad a diagnosis from over the pond...........
Re: I fear the worst [Re: DamKia] #721235 06/26/06 03:38 AM
You called it right Gary. It's amazing how fast a KIA tech found it. The guys who only work on them occasionally were in the dark.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6083 MB (Peak: 0.6799 MB) Data Comp: Off Server Time: 2026-06-10 00:09:15 UTC
