Page 1 of 3 1 2 3
2.7L Runner Q #721391 05/06/06 02:43 AM
kewlynx Offline OP
How do you 2.7L guys/gals like your Runners?
Am quite seriously looking at a '99 4dr-- test driving it Saturday in fact. Private deal at $10.2K
Looks like it's been a grocery-getter all its life. SR5, 5-speed AND cruise!! <img src="/forums/images/graemlins/smile.gif" alt="" /> Has 104K miles on it. Already checked the Carfax on it; good to go.
I'm not a go-fast person; too many moose and a long commute.
Thanks for any input!
**ubi apis- ibi salus**
Re: 2.7L Runner Q [Re: kewlynx] #721392 05/06/06 03:09 AM
I had a 2.7L in my 01 Tacoma and it had good power and never had any problems with it at all...Great motor.
Re: 2.7L Runner Q #721393 05/06/06 03:28 AM
kewlynx Offline OP
Thanks; I know this engine has about the same ponies as the 3.sl0w; the 22Rxx's in a Runner was a bogger with the weight diff between a Runner and a pup. I have a friend with a pup and 2.7; he loves it!
I do have another q. now that I'm thinking about it. In the back, is there any electrical accessories points back in/near the cargo area? I'd like to be able to eventually wire up a fan back there for the new pooch and keep her comfy on our road trips.
Re: 2.7L Runner Q [Re: kewlynx] #721394 05/06/06 04:19 AM
hupptoy Offline
My 99 has a power outlet in the back right corner and 3 in the dash.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: 2.7L Runner Q [Re: hupptoy] #721395 05/06/06 12:19 PM
nuclear3579 Offline
I specifically bought a 97 runner with the 2.7, and I can't say enough great things about it. It's got plenty of power yet a smoother clutch engagement than the V6. If I had to get another truck, it would be without hesitation another 2.7L 4cyl. <img src="/forums/images/graemlins/cheers.gif" alt="" />
EDIT: Gas mileage isn't bad, either. I do alot of city driving (alot of ideling at red lights), and I've yet to get below 20mpg. NOT bad for a 4 wheel drive SUV. Not that the V6 is a gas guzzler, but when I'm stuck in heavy traffic, I'd rather have the 4cyl eat gas than any V6.
Too close for missiles, I'm switching to guns...
'97 4Runner...SR5, 4cyl (3RZ), 5spd, 4wd, no rust, excellent shape.
Re: 2.7L Runner Q [Re: nuclear3579] #721396 05/06/06 04:48 PM
Edy Offline
I'm in the same boat as kewlynx. Got a 98 4cyl to look at 2 counties south. It's got 200k with head gasket and clutch done 25k ago. The owner claims that it's flawless otherwise. I'm replacing (or retiring to trail status) my rusting 85 Runnner. Any word on how these hold up to the long haul. My old runner has 340K on the body and about 120K on the motor. Can I expect the same reliability out of the 2.7?
85 4Runner 22re, mostly stock. Over 340K miles(SOLD for $4000 7/06)
98 2.7 4cyl 4Runner Bone Stock perfect 200,000 miles (alright, it has a HG and clutch in it's past)
Re: 2.7L Runner Q [Re: Edy] #721397 05/07/06 01:14 AM
kewlynx Offline OP
Some great input here so far. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Went and messed around with the rig today. CV boots not cracked (common up here in the cold). Got a couple rock dings in the windshield my glass guy can take care of for about $40; might wait til the end of the summer to take care of, as I've got an intersection to go thru that's started construction for the summer (ZERO detour).
After a bit of confusion, we found the jack kit to be stowed under the rear pax seat, but can't get the darned cushions up; there a trick? We fooled with it quite a bit, and couldn't get the buggers up. Had the owner's manual handy too. <img src="/forums/images/graemlins/confused.gif" alt="" />
Yep, rear cargo has a plug-in for the pooch's fan; crate dimensions work awesome too! <img src="/forums/images/graemlins/smile.gif" alt="" />
Tow package is Toyota. I need to get load specs for it.
A bit annoying that the rear pax heater fans take up room under the front seats. That could been a duct setup under the console easily enough; all the rear accessories work tho'.
My other two q's would be if the FWD is ADD/autohubs up front, and if it's ABS. I did a full panic stop from 60mph, and it was solid, but without the feedback thru the pedal like what I've experienced with other ABS systems.
VERY tight shifting pattern; kind of fun to fool with cruise on a stickshift-- they used to call that a throttle control! <img src="/forums/images/graemlins/lol.gif" alt="" />
**Owner had it in 4WD full time during Jan/Feb, and was getting around 20 mpg, guess out of 4WD to be about 23 mpg.
Gotta find a screw for the trim fairing along the driver's seat; looks like it was removed at one point. No rattles otherwise; very sound. Nary a tear nor scuff otherwise.
Looks like I'd be able to work on this puppy once I get familiarized. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Quite the change from the ol' 22R mills I've got around my place! On the 2.7's, I briefly read something about a tendency toward sludge, but haven't found anything else, nor documented online at least.
A 4 banger is still cheaper coming out of the machine shop than a 6 banger if rebuilding later on, by about half. That's per my local machinist as of about 9 months ago.
Seller was a little pizzed that I offered $9500, as there was no maintenance documentation from the previous owner (I'll be #3 if I get it), but she also knows I'm already preapproved for my loan, so we'll see....am trying to find out how much is still left on her lien; new finagling for me, as last time I bought anything, it was Ol' Blue off the lot.
That means I get the joy of finding out if stuff like the timing belt and fuel filter, etc has been swapped or not. While looking at the CV boots, frame, and the engine, looks like this rig has truly been a pavement queen.
Cool. I'll be 46 this summer, so this will be the last rig I ever hafta buy if I don't hit anything. Wish me luck!!
Re: 2.7L Runner Q [Re: kewlynx] #721398 05/07/06 05:55 AM
hupptoy Offline
Some times you need to push the back of seat cushion down a little and pull the loop forward and up to keep the plastic from hanging on the seatback. I have to do this on that side because I squeezed a 30'x2" strap in with the jack.
Yes ADD, No autohubs. Hubs are always "locked." If you have ABS and get it to activate on a 4Runner, you will definetly notice it cause it makes quite a racket. Maybe have the dealer punch in the VIN to see if it has ABS or IIRC the ABS is (on my 3.4) in front of the firewall on the passenger side (block with lots-o-brake lines).
Still has a timing chain on the 2.7, so no belt to mess with.
The 3rd gen Runners are definitely a step up in comfort.
hupptoy
Re: 2.7L Runner Q [Re: hupptoy] #721399 05/07/06 06:17 AM
kewlynx Offline OP
Thank you!! See? Learnin' already <img src="/forums/images/graemlins/smile.gif" alt="" />
If I wind up with this thing, I need to run the VIN by the dealer anyway to determine if there's a factory alarm on this thing in addition to the tow bar specs. Owner doesn't know diddly in some respects. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
No ABS noise, tho' when the insurance folks worked up a quote for me, I got the ABS discounted. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I should know something by the end of next week, if not sooner.
Re: 2.7L Runner Q [Re: kewlynx] #721400 05/07/06 07:00 AM
hupptoy Offline
I think all alarms were dealer/port installed, so VIN may not help there. And, IIRC, 2.7's are rated to tow 3500 lbs.
hupptoy
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6462 MB (Peak: 0.7752 MB) Data Comp: Off Server Time: 2026-06-07 05:43:39 UTC
