ECU temp sensor question... #721470 05/06/06 06:57 PM
Scotty_Gotti Offline OP
Hello, can a failing ECU temp sensor cause the truck to run rich and of rough? Also, how easy is this to replace? thanks
Re: ECU temp sensor question... [Re: Scotty_Gotti] #721471 05/06/06 07:23 PM
4Crawler Offline
Sure. Why? If ECU thinks the engine is cold, it richens up the fuel mix to make the engine warm up faster.
Re: ECU temp sensor question... [Re: 4Crawler] #721472 05/06/06 11:49 PM
what is this temp sensor, and where is it.... I need Pics. im a dumazz and i think this is the problem im having with my runner too. 22re
Re: ECU temp sensor question... #721473 05/07/06 12:43 AM
4Crawler Offline
Re: ECU temp sensor question... [Re: 4Crawler] #721474 05/07/06 02:51 AM
thanks, that helps. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: ECU temp sensor question... #721475 05/07/06 02:13 PM
ok so lookin at the fsm is it nessesary to remove the sensor? or just test it with the motor cold then hot.
Re: ECU temp sensor question... #721476 05/07/06 02:37 PM
4Crawler Offline
Can be tested in place or removed, whatever works for you. In place you'll only have a rough idea of the coolant temps, so you can just get a ballpark guess on whether it is working or not.
I recall checking mine when I had the intake off and took it out and cleaned off the side in contact with the coolant.
Re: ECU temp sensor question... [Re: 4Crawler] #721477 05/07/06 03:11 PM
it def. sounds like a problem with that sensor or the egr. would this make it send a code? is that temp sensor the one labeled BVSV? im gunna check these few things. if I can't find the problem will the stealer find the problem for me for a diagnostic fee? and if so can I then just fix it myself without them doing the $$$ labor? i would hate to do this but I just want my new motor to run perfect.
sometimes it runs great when warm and sometimes it idles really low and rough cold or warm, but almost always hesitates before gettin on it
Re: ECU temp sensor question... #721478 05/07/06 03:25 PM
4Crawler Offline
The BVSV is the Bimetal Vacuum Switching Valve that sends vacuum to the EGR modulator once the engine warms up to let is start operating.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6227 MB (Peak: 0.7245 MB) Data Comp: Off Server Time: 2026-06-07 07:04:23 UTC
