throttle body cleaning question... #721479 05/06/06 06:58 PM
Scotty_Gotti Offline OP
whats the best (and safest) way to clean the throttle body?
Thanks
Re: throttle body cleaning question... [Re: Scotty_Gotti] #721480 05/06/06 07:22 PM
4Crawler Offline
Remove it and pull the TPS off, then clean with EFI or carb cleaner and a brush including the small vacuum passages. Reinstall and set the TPS and it should be good to go. Avoid getting cleaner in the TPS (especially if you don't pull the TPS), or you may be in the market for a new TPS!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5890 MB (Peak: 0.6369 MB) Data Comp: Off Server Time: 2026-06-07 04:34:21 UTC
