help identify AC component
#721765
05/08/06 03:03 AM
Howdy. I've got an AC leak and I've got dye on a component indicating where the leak is. Problem is, I don't know what it is, whether it's part of the AC line it's connected to, etc.. It's the rectangular piece that is on the AC line, and is between the front grill and radiator (or condenser) next to the canister with the sight glass. I have the OEM factory manual, but it doesn't help.
Clues???
Also, if anyone knows something about replacing it, please let me know.
thanks [img]http://pg.photos.yahoo.com/ph/cyndyschaefer/album?.dir=a59escd&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/cyndyschaefer/my_photos[/img]
Re: help identify AC component
[Re: tim_s]
#721766
05/08/06 03:26 AM
I'm not sure what it is, but I think I have a new one. Look at the end of the line sticking out of the box... What vehicle do you own?
[Re: H2O_MAN]
#721767
05/08/06 03:51 AM
oops... it's a '98 T100. The component in your picture doesn't look quite like the one I have that is leaking, but then I haven't seen it from any angle other than from above. Still, the one in your picture appears smaller....
[Re: tim_s]
#721768
05/08/06 02:45 PM
its on a low pressure line. take off the grill and take it out. there's going to be an o-ring in there and it has failed.
[Re: Squeezer99]
#721769
05/08/06 10:29 PM
Toyota Moderator
The blocks on the ends of the lines are just the type of fittings they use. As was mentioned, they use o-ring seals (which can be seen in the pic that H20man posted). The line itself could be bad, but more likely its the o-ring.
[Re: ErikB]
#721770
05/09/06 04:43 AM
Thanks all. I got the grill off, cleaned the area and drove around to check for the leak. It does look like the o-ring is the problem. I guess the dealer is the only place to go to get the correct o-ring. I've not had luck before going to the auto parts store for such parts before.
[Re: tim_s]
#721771
05/09/06 03:14 PM
Toyota Moderator
I haven't had any problems getting my local NAPA to find me matching o-rings when I bring them in. A/C shops will have them too. But the dealer will work...
[Re: ErikB]
#721772
05/10/06 03:18 PM
When you replace an "O" ring in an AC system, do you coat it with silicone lube or anything or just put it in dry?
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
[Re: garym]
#721773
05/10/06 04:59 PM
[Re: garym]
#721774
05/10/06 08:38 PM
you should lube it up with compressor oil, or whatever type of oil is used in your a/c system.
