6NZ...where to find it? #721844 05/08/06 05:09 PM
ducktrooper Offline OP
Am trying to find carrier assemly w/4.77 gears from '89-91 Troopers. Most Troops in salvage yards show up on their computers as only having 4.56 ratio. Where does one find the code 6NZ that indicates wide tire package w/4.77's? Would this be in the VIN or stamped on the info plate?
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: 6NZ...where to find it? [Re: ducktrooper] #721845 05/08/06 06:09 PM
chasespeed Offline
Should be stamped on the plaquard under the hood, maybe also in the glove box or something like that on a 1st gen..
Chase
Chase
Re: 6NZ...where to find it? [Re: chasespeed] #721846 05/08/06 06:24 PM
RobG Offline
good luck. it might be easiest to search for '89 Trooper RS's (2dr, SWB)... though rare themselves, consensus seems to be they all have 4.77's.
-Rob
Re: 6NZ...where to find it? [Re: ducktrooper] #721847 05/09/06 06:20 AM
Socalboke Offline
If you look on the options tag on the firewall the wide tire option is listed as C-60, I don't think that the actual ratio is listed other than tracing the VIN and getting the spec sheet.
Reid
Reid
96 Trooper, 94 Amigo, 89 swb RS trooper
Re: 6NZ...where to find it? [Re: Socalboke] #721848 05/09/06 11:39 PM
JLEMOND Offline
HMMM C-60 ON ALL MY FACTORY OPTIONS LIST MANUAL AIR COND, CONTROL ..6NZ SHOULD BE THE CODE FOR THE WIDE TIRE OPTION JERRY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-05-29 16:35:34 UTC
