I just ruined an FJ40 tie rod end. How come? #721991 05/09/06 02:54 AM
ScaldedDog Offline OP
***EDIT - It was an FJ80 TRE ***
According to Marlin's site, torque specs are 80-100lbs. I had my wrench set to 85, and it just kept turning. Finally stripped the nut.
I had anti-sieze on the threads, which I'm now thinking was a mistake. The nut turned down far enough that the cotter pin holes were completely above the castle nut.
I never thought I'd ask something so simple, but can someone tell me the *right* way to do this? I clearly haven't figured it out.
Mark
''Wise men talk because they have something to say; fools,
because they have to say something.'' - Plato
http://www.scaldeddog.com
Re: I just ruined an FJ40 tie rod end. How come? [Re: ScaldedDog] #721992 05/09/06 03:33 AM
XJCreeper Offline
Don't know about the FJ tie rod, but 80 foot pounds of torque sounds like a bit too much my 85 FSM says it should be 67 foot pounds. The knuckle arm at the steering knuckle gets 80 foot pounds. As for the threadlock adding to the trouble I think you are on to something. I once found out as you have that using the threadlock when wet provides a bit of lubrication on the threads and makes it easier to turn. This really throws off the torque wrench reading. With castle nuts and cotter pins you shound not need the threadlock to keep it from loosening.
Re: I just ruined an FJ40 tie rod end. How come? [Re: ScaldedDog] #721993 05/09/06 04:50 AM
kewlynx Offline
Yes, to reiterate XJ's reply, torque IS affected by lube, regardless of the application. Usually if you need loctite or some other product, the service manual will tell you so.
**ubi apis- ibi salus**
Re: I just ruined an FJ40 tie rod end. How come? [Re: kewlynx] #721994 05/09/06 05:01 AM
Just to be clear, it wasn't locktite I was using, it was Permatex anti-seize. I put it on the TRE mating surface to make them easier to remove, then decided to put it on the threads, too. Bad idea.
Mark
Re: I just ruined an FJ40 tie rod end. How come? [Re: ScaldedDog] #721995 05/09/06 02:08 PM
OOP'S Offline
Did any of the other nuts do it? As you were answered over on PBB, I believe the nut was not as good as required. Either the heat-treating was wrong or the thread specs were not right. I do not think the anti-seize had anything to do with it.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: I just ruined an FJ40 tie rod end. How come? [Re: OOP'S] #721996 05/09/06 06:31 PM
Red_Chili Offline
Toyota Section Staffer
I'm on shakey ground here, because I am about to disagree with David... <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> (he is usually very right)
Wet torque is NOT the same as dry torque. Ask me how I found that out... same way ScaldedDog did +/-.
-Bill
Re: I just ruined an FJ40 tie rod end. How come? [Re: ScaldedDog] #721997 05/09/06 07:34 PM
Brian894X4 Offline
As already mentioned, the spec I got from A/P regarding my FJ80 tie rod is about 67 ft/lbs and I worry about stripping them out at that torque. 80-100ft/lbs sounds insane to me.
Re: I just ruined an FJ40 tie rod end. How come? [Re: Brian894X4] #721998 05/09/06 07:38 PM
Red_Chili Offline
Do mine around 70 IIRC- confirming Brian. Always dry.
-Bill
Re: I just ruined an FJ40 tie rod end. How come? [Re: Red_Chili] #721999 05/09/06 08:22 PM
OOP'S Offline
No problem, I am glad when people point out when I am wrong about something, makes me learn something new. Therefore, I did a bit of research on Google by inquiring "Torque Specs" and this is what I came up with. These are all dry specs:
Metric Steel Bolts Torque Specifications
Standard Dry Torque in Foot-Pounds
Bolt Size Millimeters-----------------------------14mm
Coarse Thread Pitch-----------------------------1.25
Standard 5D 71,160 psi Med. Carbon Steel--------55 ft lbs
Standard 8G 113,800 psi Med. Carbon Steel-------89 ft lbs
Standard 10K 142,000 psi Med. Carbon Steel------117 ft lbs
Standard 12K 170,674 psi Med. Carbon Steel------137 ft lbs
Now the question is, what are they made from?
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6301 MB (Peak: 0.7332 MB) Data Comp: Off Server Time: 2026-06-07 04:34:59 UTC
