most likely dumb question on IAC motor #722555 05/11/06 12:24 AM
silverwriter Offline OP
I've read many times how the IAC motor helps keep idle RPMs up when the air conditioning is on... and figured mine was always dead (have cleaned it to no avail) as the A/C always brought RPMs down.
Well, recent tinkered made me aware of the power steering pressure switch, which DOES raise my RPM by about 200 whenever the wheel is turned hard at a stop. So, is the IAC involved in this process? Does this mean mine works? If so, what lets the ECU know that the A/C is on? Is it hard-wired somewhere/somehow? Just wondering if I should be looking for a failed sensor or disconnected wire.
Thanks for any help in understanding how this works.
Bryan
Dallas, TX
Gen I 4-door 3.0 V6
'89 4-Door Montero 3.0L V6
'04 Jeep Grand Cherokee 4.0 6L
Re: most likely dumb question on IAC motor [Re: silverwriter] #722556 05/11/06 01:42 PM
conner Offline
Yes, the idle speed shoud increase to compensate for AC load. When the ECU sees the imput from the AC temp switch, it should provide a ground to the AC compressor relay and increase idle speed. The same thing occurs with the P/S which pulls 8 volts to ground in the ECU ( when pressures are high) and the ECU will increase idle speed. The same thing should occur when the transmission is placed in drive.
Conner
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: most likely dumb question on IAC motor [Re: conner] #722557 05/11/06 05:22 PM
Thanks for the info! Seeing as how I do get increased RPMs with the steering pressure and drive selection... I'm going to test the A/C temp switch and relay ground before I spend money on a new IAC.
Bryan
Re: most likely dumb question on IAC motor [Re: silverwriter] #722558 05/11/06 06:49 PM
That's good to know, conner. How does the ecu know? shift sector switch?
Re: most likely dumb question on IAC motor [Re: fasteddy] #722559 05/11/06 07:55 PM
conner Offline
Yes Ed, or what Mitsubishi likes to call the "inhibitor switch."
Conner
Re: most likely dumb question on IAC motor [Re: conner] #722560 05/12/06 03:48 AM
So if I hotwire the inhibitor switch so I can crank the truck in whatever gear I want to, the idle will stay high all the time (like it does now anyway with a no-go ISC)?
Re: most likely dumb question on IAC motor [Re: fasteddy] #722561 05/12/06 12:18 PM
conner Offline
Ed: We were discussing the 3.0 engine here. I am assuming that you are using the Starion system on yours. It may well work the same however i dont have a wiring schematic handy to see where that input comes from. I will try to find one and get back.
Conner
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.011s) Memory: 0.6156 MB (Peak: 0.6939 MB) Data Comp: Off Server Time: 2026-11-03 11:41:01 UTC
