Clock is weird #722795 05/11/06 06:20 PM
wsquaredodie Offline OP
My dash clock display fades out. when I just touch it it comes back into view for a few seconds. Time is correct, so clock is working, just have no readable display. Anyone have this one pop up and what to do to fix, if anything?
trafdlo
Re: Clock is weird [Re: wsquaredodie] #722796 05/11/06 07:20 PM
hupptoy Offline
The clock on my 99 4Runner did this a couple of times 2 weeks ago (during the same short trip). Hasn't done it since, so I have not needed to look for a fix yet.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: Clock is weird [Re: wsquaredodie] #722797 05/11/06 11:24 PM
garym Offline
I have not seen it on the T but I work with similar displays and usually it is the internal connections between the segments and the drivers that start to come apart. When you press on them it is enough pressure to reconnect but it goes away. Unless you have a loose power wire to it that you are disturbing it is probably going belly up. <img src="/forums/images/graemlins/barf.gif" alt="" />
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Clock is weird [Re: wsquaredodie] #722798 05/17/06 03:16 AM
T-Rex Offline
Before I sold my T last year, I had had the same problem. The problem only got worse over time. I think the only fix is to replace, or to just upgrade your stereo that has the built in clock and not worry about it.
02 Tacoma Double Cab TRD Prerunner .. just added 3" lift .. more to come
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6022 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-05-29 19:50:05 UTC
