oil spark plugs #722841 05/11/06 11:04 PM
in my 96 rodeo 3.2 i just did a spark plug change and i notice that number 1&3 spark plug was coverd in oil including the cap that covers the spark plug i have never seen this before should i replace the piston rings or is it something else? just thought i would ask <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: oil spark plugs #722842 05/12/06 01:21 AM
CPOM Offline
search around the board for this problem I believe there is a problem with the head/valve cover and some type of gasket that allows oil to enter the spark plug boots. May not be a serious engine problem.
CHRIS
98 Amigo, 92 Pup
Re: oil spark plugs #722843 05/12/06 03:53 AM
V
vanduker Offline
Most likely the seals between the valve covers and the spark plug "tubes". If it bothers you enough or is bad enough and you can change a valve cover gasket you can fix this. Unless it is bad I would let it go.
Re: oil spark plugs [Re: vanduker] #722844 05/16/06 10:46 PM
I
igneous Offline
One thing the plugs do is dissipate heat off the combustion.
Having oil in the tubes will impede this to a degree and eventually get into the wire>>rough running. I'd do a vcg change.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5943 MB (Peak: 0.6512 MB) Data Comp: Off Server Time: 2026-06-23 14:16:52 UTC
