Re: IFS kit? #722913 05/13/06 02:08 AM
shanef Offline
i had the 4 inch pro comp in my old truck and it was wheeled very hard, seen a lot of jumping and i had no probloms with it
03 extra cab 3 inch suspinsion lift 2 inch body lift 35 bfg mt's and some other stuff
Re: IFS kit? #722914 05/13/06 03:31 AM
jcssurf Offline
You could fit 35s with your 3" body lift that you have now.
Skip the 4" suspension and buy something that will really help you offroad, like gears and lockers. If you want to gain some breakover clearance, which is all an IFS lift does, get a high clearance skid and do a drivetrain lift for around 300$ total.
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: IFS kit? [Re: jcssurf] #722915 05/13/06 08:41 AM
Snowtoy Offline
You should be able to clear the 35's right now with some fender moding. On the '91 trail rig I am building, I have a 2" BL, and it currently has 315's BFG MT's that are 34.5" tall when installed on the truck. I have cut the fenders and massaged the cab back to the body mounts. Right now everything clears with normal driving. I plan on running some ball-joint spacers for extra clearance and to increase the articulation a little more. The rear wasn't a problem since I am fabbing up a flatbed for it. You would have to cut the rear some, no problem if you are running cut-out fender flares.
Re: IFS kit? [Re: Snowtoy] #722916 05/14/06 07:45 PM
bassplaya Offline
ive heard that stock wheels wont fit with some IFS lift kits like the superlift. can anyone tell me if this is true
94 Pickup DLX V6 stock as stock can be, but not for long.
Re: IFS kit? [Re: bassplaya] #722917 05/14/06 07:56 PM
bkg Offline
They fit just fine... however, you cannot run a tire any wider than a 9.5 on that wheel and still clear the upper a-arm. A 12.5 will definitely interfere w/ the a-arm and potentially rupture the ture.
Brian K. Gallus
Re: IFS kit? [Re: bkg] #722918 05/14/06 08:38 PM
jcssurf Offline
I think a 10.50 on a stock wheel will fit with an IFS lift. Someone on here runs them.
Snowtoy, do you have any pics of this rig? I've thought about 315s with a 2" body because I've got some 16" wheels lying around. Thanks!
-Driver
Re: IFS kit? [Re: jcssurf] #722919 05/15/06 08:56 AM
Snowtoy Offline
Hear is a side shot.
I will try to get some close-up shots if you want.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6226 MB (Peak: 0.7128 MB) Data Comp: Off Server Time: 2026-07-16 03:39:00 UTC
