3VZE PCV valve replacement #723023 05/12/06 08:50 PM
1
10_35lookoutbelow Offline OP
I have tried to get the PCV valve out on my truck and it is turning out to be a PITA. That thing is in there good and there is not much room under the intake manifold to pry it out. I pried a little by getting a screwdriver under the rubber grommet but I just broke the lip off the grommet. I decided to walk away and take a minute before I get that thing stuck in there and have to start pulling the intake off. Anybody have any experience/knoledge to help me out a little?
Theresa the Toyota Terror-89 Toyota P/U (3.0L SR5, 5sp swapped in from auto, 3"B.L., 32X11.5X15 MT/R, 2.5" stainless magnaflow catback exhaust, leaky floor with cold draft @feet, FUBAR comptron now in glovebox)
Re: 3VZE PCV valve replacement [Re: 10_35lookoutbelow] #723024 05/12/06 09:55 PM
oh, that sucker is tough to get out. I once did it by removing the exhaust pipe that goes to the EGR vavle to get some room. Removed some of the vaccum lines too. I used a combination of things, from long screwdrivers to pry it out, and lock pliers to get a grip and pry it out. Its tough. I dont know if like WD-40 would help (just thought of that). It's pretty tough, but can be doable. Just dont break the whole groment that you have to remove the valve cover to take the pieces out!!! If you can't....then the top intake must come off. Not that hard though. Good luck!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 3VZE PCV valve replacement #723025 05/13/06 12:19 AM
OOP'S Offline
I would use silicone spray instead of WD-40. They are a real bummer to get out and it sounds like to me if the grommet is that brittle it to should be replaced.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 3VZE PCV valve replacement [Re: 10_35lookoutbelow] #723026 05/13/06 08:12 AM
Myredyota Offline
I tried everything in all my tool boxes and could not get it out. I ended up pulling the plenum and then relocated the PCV with elbows and hose to a spot I can get to if I ever need. [Linked Image]
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5961 MB (Peak: 0.6541 MB) Data Comp: Off Server Time: 2026-10-24 13:02:00 UTC
