somethings going out
#723308
05/14/06 04:14 AM
its either my starter or my nuetral safety switch. i push the clutch in and it trys to start(like it turns over once or twice and stops), or it clicks. then i try it again and fires up.
now the real problem it doesn't do it all the time, so i can't diagnos it <img src="/forums/images/graemlins/angry.gif" alt="" />
97 sr5 tacoma: TRD air filter, bilstien shocks, and a crazy sound system mods soon to come B&M short throw TRD headers MagnaFlow catback
Re: somethings going out
[Re: blue97sr5]
#723309
05/14/06 04:30 AM
Give this a read; also make sure your battery cables are clean and have good connectivity. We also have an FSM sticky'd here if you need schematics. <img src="/forums/images/graemlins/notooth.gif" alt="" />
[Re: blue97sr5]
#723310
05/15/06 06:27 PM
Sounds like a bad starter. It will be intermittent and if you cant get it to turn over try hitting the starter with a bfh (gently) and it should start. In the meantime replace the contacts.
'04 Taco x-cab 3RZ FE stock (daily driver) '90 x-cab 22RE stock '82 Hilux 6" lift (ACES HI) '82 2-Hiluxs' Rally Edition (parts) '81 Hilux 3" lift (parts/restore)
[Re: ACES_HI]
#723311
05/16/06 04:13 AM
Is it a manual? That samish thing happened to me about a month ago but then I noticed that the clutch switch was going out on the floor and the clutch start cancel solved that. Might have nothing to do with it though...
98' Toyota Tacoma SR5 Manual Xtra Cab, Slight Lift Maine Rules!
[Re: DentedTacoma]
#723312
05/16/06 08:45 PM
yeah its a manual
it starts everytime with the clutch start cancel
[Re: blue97sr5]
#723313
05/17/06 02:23 AM
Make sure the plunger for the clutch switch is properly adjusted, and that your clutch bracket isn't cracked, esp if it makes noise when you work the pedal.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6105 MB (Peak: 0.6799 MB) Data Comp: Off Server Time: 2026-11-02 12:33:20 UTCValid HTML 5 and Valid CSS
