Re: 232 or 258ci in a 1978 CJ7? [Re: JeePete] #723508 05/22/06 04:09 AM
sroyfire Offline
jp heres one for you I bought a 84 and they said the motor was rebiult but the code on mine is 108c17 yes it is a 258 but what year would you suspect?
'07 Jeep JK 2" Pro Comp Skyjacker shocks 17" Pro comp wheels 295/65-17 Pro Comp Xtreme A/T
'84 CJ-7 2" lift 32x11.5 pro comp
LETS WHEEL
Re: 232 or 258ci in a 1978 CJ7? [Re: sroyfire] #723509 05/22/06 06:05 AM
JeePete Offline
With nothing eles to go on I'd say 1981.
258's with the C code were built between 76 and 89 according to the info on the link I posted earlier. So an engine could have the same number and be built in 1977 but it would be a first generation 258 and would have come from the factory with 1/2" head bolts, a steel valve cover and a cast Iron intake manifold that would be bolted together with the exhaust manifold instead of the separate aluminum intake that came in 1981. but as I said before, heads and manifolds can be swapped, casting numbers are one sure way to tell. Here is a list I found, I haven't made any attempt to verify it yet.
1975-79 258 4.2L 1/2" Head bolts
Blocks: 3227445 and 3224098
Head: 3227258
Crank: 3214723
1980 258 4.2L 1/2" Head bolts
Block: 3235077
Head: 3227258
Crank: 3214723
1981-85 258 4.2L 7/16" Head bolts
Block: 3235444
Heads: 3933000, 3224480, and 3241656
Crank: 3235477
1986 258 4.2L 1/2" Head bolts
Block: 3227444
Head: 3933002
Crank: 3235477
Re: 232 or 258ci in a 1978 CJ7? [Re: JeePete] #723510 05/24/06 05:35 AM
sroyfire Offline
thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
LETS WHEEL
Re: 232 or 258ci in a 1978 CJ7? [Re: JeePete] #723511 05/28/06 03:40 AM
burtv Offline OP
Where are the casting numbers located on the engine? I have looked but can't find it. Probably was right in front of me!
78 CJ7, 83 wide track axles/Dana 30 Front W/ OX Locker, Model 20 rear w/ one piece shafts(welded tubes)/Detroit Locker, 4.10 gears. 4.5" spring lift with 3/4" shackle lift. 35x12.50 BFG MT, 4.2L, Weber Carb, K&N, T18,Scout Dana 300,Warn 9.5ti
Re: 232 or 258ci in a 1978 CJ7? [Re: burtv] #723512 05/28/06 05:27 AM
JeePete Offline
I've never looked for them but I imagine they are on one side of the block or the other. They may be obscured by engine mounts. If I remember I'll look at mine when the sun is shining and see if I can see! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 232 or 258ci in a 1978 CJ7? [Re: burtv] #723513 05/28/06 02:56 PM
JeePete Offline
On my 1984 258 the casting numbers are on the drivers side of the block, slightly rearward of the engine mount, 1/2 way between the bottom and top exposed edge of the block. Mine is hard to read because my 4.0 exhaust manifold partly covers it. I think with the stock manifold it would be eaiser to read. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6178 MB (Peak: 0.7043 MB) Data Comp: Off Server Time: 2026-05-29 21:09:14 UTC
