poser pics in the yard
#723558
05/15/06 05:51 AM
if it don't fit, force it if it breaks, it needed to be replaced anyway
Re: poser pics in the yard
[Re: blevcom21]
#723559
05/15/06 04:34 PM
Looks well balanced. Don't get crazy with too much lift there in VA. The Virginia State Troopers are death on Samurais when they are lifted. You could have a 3" lift, park next to a full size truck with 44's and a 'silly lift' (silly meaning it is too tall to actually be safe offroad) and the trooper will go after YOU for the ticket. One of the reasons I don't go back home to Virginia very often...
Bill ---------------------------- God Forgives, Rocks Don't...
[Re: Billjohn]
#723560
05/15/06 07:01 PM
well im not in va anymore im back in tennessee now and if i go yj then i will actually lose i inch of lift i have 3" lift springs and spoa the yjs only give 2"of lift so it will drop which ill lose an inch to gain mor flex its a little scary on some side hill parts of the trails around here but what i really need is a cage and a locker with some good MTs it has ats now due to all of the highway driving i used to do when i was in va
[Re: blevcom21]
#723561
05/15/06 07:39 PM
I saw the plates and had flashbacks... <img src="/forums/images/graemlins/lol.gif" alt="" />
You will like the YJ's. I started with stock 5 leaf packs all around and then went to 2" lifted 5 leaf packs out back to make up for the equipment box I carry. Itseemsthe stock 5 leaf packs were just too flexy and sunk too low. The lifted set also helped out with some spring wrap I had.
[Re: Billjohn]
#723562
05/16/06 12:15 AM
aren't the rear ones short anywaymost people have to get longer shackles in the rear to make up for it
[Re: blevcom21]
#723563
05/16/06 01:17 AM
Although I use Revolver shackles out back, you can see from the picture that the rears stick out a little anyway. The seem to be plenty long enough. ![[Linked Image]](http://www.billjohn.com/suspension/images/yjrevolver49.jpg)
[Re: Billjohn]
#723564
05/22/06 03:03 AM
i was talking about the ride hight not the lenth of the spring they make the rear sit a little lower than the front like an inch barely noticable maybe you cant tell with the revolvers
[Re: blevcom21]
#723565
05/22/06 03:28 PM
Gotcha. That is why I wasn't really happy with my ride height out back and forcedme to go to lifted (2") YJs for the rear.
[Re: Billjohn]
#723566
05/24/06 06:59 AM
i think im going to keep mine the way it is and use it as my dd cause i have huge plans for my rodeo now if i could just find a cheap used K-5 with a strait axle and a 350 manual trans. hint hint wink wink
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6285 MB (Peak: 0.7327 MB) Data Comp: Off Server Time: 2026-06-22 14:08:49 UTCValid HTML 5 and Valid CSS
