High Idle After Rebuild "Complete"
#723578
05/15/06 05:22 PM
OK, so I finally got the 22RE back together and it runs! The only issue I can tell right now is the idle is horrifically high. I disassembled each part of the intake, but I didn't replace the throttle body gasket. The others were replaced. Might this be an issue? I've investigated all of the vacuum lines and they seem to be in order. Anyone have any good ideas on how/what to check first and so on? Also, I think it needs the valves adjusted. Is there a way to do this with a cool/cold engine? I can't see getting the valve cover off in time for the valvetrain to still be warm. Thank you all (especially Enginebuilder) for your help.
Re: High Idle After Rebuild "Complete"
[Re: bikedoctor]
#723579
05/15/06 05:30 PM
I set my valves at .007" and .011" with the engine cold, this seems to keep the valve ticking away. Can you lower the idle with the idle screw? Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
[Re: Jeffstoyo]
#723580
05/15/06 07:12 PM
I probably could set the idle down with an adjustment, but the engine idled perfectly prior to my fiddling with it. I'm thinking this is an indication of something wrong and i would rather fix that than alieviate the symptoms. Thanks for the valve specs; I'll see how close I am to those this weekend.
[Re: bikedoctor]
#723581
05/16/06 02:52 AM
same thing happened to me after rebuild. i checked timing it was right on 5* with the jumper installed so i just turned the idle screw down on the intake... i think it idled higher after i got the 225k worth of black gooo out of the intake...
kevin <img src="/forums/images/graemlins/kewl.gif" alt="" />
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!*** 1989 Toyota pickup 22re 5spd 4wd *** * New mods * - 305/70/R16 (33X12.5)
- 2 in suspention lift (zuk coils)
- minor body work
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6030 MB (Peak: 0.6587 MB) Data Comp: Off Server Time: 2026-06-07 07:29:20 UTCValid HTML 5 and Valid CSS
